last problem with the 4.0 swap need help - JeepForum.com
post #1 of 2 Old 01-20-2010, 09:25 PM Thread Starter
jake89yj
ok so the lines going to the front axel are completly difrent i was wandering if its posbile to take the 4wd assemebly of the parts jeep and put it on minei mean whats a jeep with put 4wd
jake89yj is offline
post #2 of 2 Old 01-21-2010, 05:38 AM
YJBlues
YJBlues's Avatar
it should work, both have the collar for the axle, and I believe they were put in the same place, easy to tell though, unbolt the old one and put it on the new one, if it fits, the answer is yes . It's just 4 bolts basically, 7/16 if I remember right. good luck!
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
4.0 swap MM problem Macklin96 YJ Wrangler Technical Forum 4 02-24-2009 08:10 PM
ba 10/5 to ax 15 swap problem ks90yj YJ Wrangler Technical Forum 3 01-31-2009 09:17 PM
CRT swap problem vmann7 YJ Wrangler Technical Forum 4 10-25-2008 02:25 PM
2.5L to 4.0L Swap Problem 93TennYJ YJ Wrangler Technical Forum 4 09-18-2008 03:58 PM
4.0L swap Problem Hahn929 YJ Wrangler Technical Forum 9 02-17-2006 12:50 PM
