Largest tires with 3" Body Lift? - JeepForum.com
post #1 of 4 Old 02-27-2002, 08:47 PM Thread Starter
Jumpjet
I am curious what is the largest tire that I can install with a 3" body lift 32X10.5? Also what problems are there with a three inch body lift? What is the best body lift kit to purchase? I would also like to see any pictures of a wrangler with a 3" body lift.
Thanks
JUMPJET
Jumpjet is offline
post #2 of 4 Old 02-27-2002, 09:34 PM
Mdwase
Biggest tires you can fit are 33x12.50,15's but they rub on the front leaf springs when turning. For the body lift pictures, contact me at wasemiller@msn.com and I will send you some.
92 Wrangler, Black,1"Body,31x12.50
89 YJ Wrecked Head on, no roll
90 YJ, SOA, 31 Muds, 4.10's, Lockers.
Mdwase is offline
post #3 of 4 Old 02-28-2002, 09:27 AM
SBall
At one time, I had a 3" body lift and 32's. I rubbed whenever I hit a bump. And with people in the back seat, it was way worse. Since then Ive upgraded that suspension and cut my body lift in half. I like the 1.5" lift much better. I feel like my jeep is much more secure and firmly attached to the frame. Plus I do not have shifting problems like I did with the 3" body. You could go with a 1-2" body lift, and get some shackles. This would put you near the 3" lift mark. While these are not the ideal lift, I like them better than the added body lift. I have shackles that are 2" longer than stock(which provides 1" of lift) and they are much more sturdy than the stock shackles. Of course a negative to shackles is the steering becomes a little more squirrely, but not too bad.
92 YJ 4.0L, 35" Goodyear MTR's, Rough Country Suspension
SBall is offline
post #4 of 4 Old 03-01-2002, 05:27 PM
Billy Badass
I have an 88' yj with a three inch body lift and 32x11.50 on it. I used the stock rims, the do rub on the leaf springs at full turn, because I used stock rims. I adjusted my stearing stops so it dosen't hap[pen any more I only lost about a foot of turning radius. I have no problems rubbing on the fenders at all, the benifits of using a stock rim. I can still stuff them into the fender well with no trouble at all, even with a full load. You could run 33, 12.50 but you would need new rims, but unless you regeared it you will have no 5th gear. The 33"s will take out the fender flares so quick you won't know what happened. It's like trying to put 31's on a stock yj, they will fit but you won't be able to use them. Sorry I don't have any pic's, but you really don't want to go 33's I would stay with 32 if you want to be able to use it. Unless you bust new shackles on it, say 1 1/2"s that would allow you to clear 33 with a 3in body lift
Later
"Nothing like the feeling of braking something important and exspensive"
88' YJ 3" body, 32x11.50 ProComp Mud Terrain. JKBII Carb Mod. Nutter Bypass and a new ignition. White Faced Gauges with blue backlighting. Sone to come 4.10 gears and lockers.
Billy Badass is offline
4" lift 1.25 body 32 tires???? 45caljeep Wrangler General Discussion 5 02-11-2010 01:39 AM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
32" Tires, or 33" whit a Body lift? TJ_Baja TJ Wrangler Technical Forum 10 11-26-2007 03:03 PM
What are the Largest tires on '03 TJ I can get without lift? Joezilla TJ Wrangler Technical Forum 6 07-05-2003 07:23 PM
1" Body Lift (& TJ flares) ...largest tire? Stray Cat YJ Wrangler Technical Forum 2 04-24-2003 07:36 PM
