L.E.D. Dash Lights Write-Up - Page 6 - JeepForum.com
post #76 of 177 Old 11-20-2010, 05:15 AM
dodger889
You can dim an LED light if you do not try to change them very fast and do not try to use but about the first quarter of the controller.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #77 of 177 Old 11-20-2010, 06:39 AM
Mistic
Dodger....you are correct about LED's capable of being dimed however I think it depends on the color. Different colors run at different voltage ranges. The only reason I say this is because my red led located in my dash will not dim at all. They are either lite or off, no matter how slow you roll the dimming dial. However a couple of white ones I have else where in my jeep will dim down.
2013 JK Wrangler Two Door with 3.6L VVT Engine
1987 YJ Wrangler with 1998 4.0L Cherokee Engine
Mistic is offline
post #78 of 177 Old 12-07-2010, 04:17 AM
SunDevilJeeper
damn it! now i can't decide, green or red.
the ships in the navy black out during the night and use red lighting inside the ship. they do that because it doesn't kill your night vision and also when someone opens a hatch to go outside during the night its harder to see the light coming out of the hatch. (but i never served on a ship so any fleet sailors please correct me if im wrong)
i was gonna do that for my dash lights because of that reason.
but now that i've seen green... thats ****in badass.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #79 of 177 Old 12-07-2010, 04:58 AM
94yjsahara
I have it in red. and its fxckin badass! with matching coloured cd deck
94yjsahara is offline
post #80 of 177 Old 12-07-2010, 11:53 AM
squarelight94
Found an article about the military using a certain color, sounds like there switching over to green for their application, but like the article suggests GREEN light has greater negative effects if its bright. I swapped my dash to RED and they're pretty bright (when they're all working lol)
http://www.equipped.com/nitevision.htm
squarelight94 is offline
post #81 of 177 Old 12-08-2010, 08:25 PM
mdreher
great thread
mdreher is offline
post #82 of 177 Old 01-04-2011, 08:39 PM
McFatter
this is a great thread! im looking into doing my 92 with all blue and its been hard to find a good post with this much info! When I do mine i will post pics as well
McFatter is offline
post #83 of 177 Old 01-05-2011, 08:42 AM
ncreptile
The blue LEDs can be dimmed pretty well, although why you would want to I dont know. Mine are perfect, not to bright, not dim.
ncreptile is offline
post #84 of 177 Old 01-05-2011, 12:10 PM
Xpress
So how bad is it if they can't be dimmed? My dimmer switch is blown, so all of my dash lights are wired directly to a hot wire I found going into the dimmer, and i'm thinking about getting red LED's...
Xpress is offline
post #85 of 177 Old 01-05-2011, 01:47 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
I leave my red LEDs on full, and I love it. I've tried dimming them just to see if it works, but my dimmer shuts the LEDs off. Even if the dimmer did work I wouldn't use it anyway.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #86 of 177 Old 01-07-2011, 01:33 PM
Mistic
Like I mentioned a few threads up the the Red LED's are not dimable from the factory roll switch. With that said I have no problems with the LED's being too bright. The Red is very easy on the eye, the gauges are real easy to read with the red lighting and I would be the first to complain if the cab was illuminated with a red glow from the dash. In my opinion they are just the perfect brightness.
Mistic is offline
post #87 of 177 Old 01-07-2011, 01:37 PM
Mistic
Also if for any reason after you purchase the LED's, you feel the gauges are too bright...you can alway remove some of the LED's from the back of the gauges which would dim down the brightness. There are several LED's in each gauge cluster to illuminate everything to a comfortable viewing brightness. However I actually installed one of the LED sockets in backward and that specific gauge was only being lite half way. The gauge was still viewable just a little bit on the darker side for my liking.
Just another suggestion!
Mistic is offline
post #88 of 177 Old 01-07-2011, 01:42 PM
celticluck713
i have green and the dimmer will not work it needs to be set just right for them to even be on.
celticluck713 is offline
post #89 of 177 Old 01-07-2011, 01:43 PM
Jims-87YJ
1987 YJ Wrangler
So no one has done this with White face Gauges? If you have please post up how you like it and what color you are using.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #90 of 177 Old 01-09-2011, 01:36 AM
xavierquinn
Has anyone tried multi color their gauges? I.E. blue lit numbers and a red needle.
xavierquinn is offline
Troubleshooting water under the dash, write-up, how-to...... rustywrangler YJ Wrangler Technical Forum 65 06-08-2017 07:44 AM
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 05:33 AM
YJ to CJ dash swap write up with pictures rrisher YJ Wrangler Technical Forum 171 05-11-2015 04:53 PM
Any write ups on how to swap the dash? tank07 YJ Wrangler Technical Forum 2 05-20-2009 02:55 AM
LED Dash Gauges Write-up Grewe02 TJ Wrangler Technical Forum 57 02-15-2007 12:24 PM
