L.E.D. Dash Lights Write-Up - Page 4 - JeepForum.com
post #46 of 177 Old 05-02-2010, 01:27 AM
Wheelman286
I just ordered my Blue LEDs and my 1 Red LED. When I get it all put together I might post a video of the tach at work and pics of the complete product as well. Mine will look different because I'm the only one on here that I know of with whited-out stock gauges that's doing this.
92 Wrangler 4.0 5-speed -Canyon Blue Metallic/Black Interior '00 S2000 Silverstone Metallic/Red Interior '93 S-10 Blazer Tahoe LT Black/Grey Leather Interior
Wheelman286 is offline
post #47 of 177 Old 05-02-2010, 05:39 AM
dodger889
As far as the indicator lights go if you match the color of each display they will still work. Like green for the turn signal. The stock color filter will let a matching color through. Which will a little brighter than using white since there is no true white led. As far dimming the light depends on two factors on the dimmer and two the LED used. So good luck on doing your projects.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #48 of 177 Old 05-05-2010, 10:07 PM
Wheelman286
I have a recommendation for people with '92 and up Jeeps. Get the 5-LED bulbs with the wide angle instead of the 6-LED bulbs. I bought the 6-leds and now I'm having to reorder because the 5 LED I ordered for the HVAC worked better in the gauges (including the middle ones) than the 6-LEDs.
The red one I ordered for the tach is not as bad as the blue ones, but it still is not enough angle to evenly light the gauge. You probably need at least a 120 degree LED and the 6-LEDs are only 35.
and by the way a 6-LED worked just fine in my HVAC... it was dim but pretty even. Those controls don't need to be bright anyways.
The 5-LED in the left side of my tach lights as evenly as an incandescent bulb
Just thought I'd save you time and money by not letting you make the same mistake I did.
post #49 of 177 Old 05-05-2010, 10:12 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Can you post pictures as well as the model # of the bulbs you are referring to? I can update the first post with more info when you do.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #50 of 177 Old 05-05-2010, 10:16 PM
Wheelman286
It"s on the same website as the ones you bought. It's in the same group with the 6-LEDS just one up from them in the box.
Some of the other ones down the page could be even better but I'm already nearly 60 bucks in so I'm done experimenting since I found something that works well.
Though having said that... this mod is probably worth well over 100 bucks to me since I've been trying to match my paint with my dash lights for going on 6 years now. It's also because of how infinitely better LEDs look than stupid fading dyed incandescents. I have a blue flashlight, blue fire extinguisher, etc. I like to match everything but I had all but given up on blue in my gauges because it takes those about 3 months to fade out and they look too much like white to start with.
post #51 of 177 Old 05-10-2010, 12:42 PM
Wheelman286
Well guys I have to say I wish my cellphone cam could do this justice. But no I'm going to have to break out the SLR for this one so it will be a little bit before I get around to it.
It was like a dream when I flipped this setup on for the first time because it was EXACTLY like I had always envisioned it would be when I got it perfect.
I seriously almost had to go change my pants afterwards it was that perfect!
Here's what I did: (all these bulbs are from the website recommended by the thread starter)
I went with mostly blue
tach: 2- 5-WLED bulbs
Speedo: 1 -5-WLED in the top
1 -6-WLED in the bottom
Other 4 gauges: 2- 5-WLEDs (you only need 2 of them for all 4 gauges so don't buy 4 like I did)
HVAC: 1- 6-WLED
-I lost my dimmer but it doesn't matter because they are the perfect brightness with this setup. The website sells load blocks you can splice into the line to get the dimmer back.
-The 5-WLEDs are the funny looking ones with the 1 LED pointing forward and the 4 under it pointing in all directions sideways... lights up the gauges just like an incandescent... possibly better with a more even coverage.
There are NO bright spots on the gauges other than a few of the ones you get with normal bulbs.
That's all I changed this time but I might go back and change all the warning, signal, and 4WD lights later when I have extra cash.
post #52 of 177 Old 05-11-2010, 09:33 AM
Wheelman286
Here's the pics... they kinda look electroluminescent in person... which is ****ing fantastic!
And if anyone sees another Tachometer like this they now know where it came from... me... hehe. I have laid claim to the idea by being the first to post it publicly (as far as I know).
I put a red bulb in the right side and a blue in the left. you can get a simmilar effect with the speedo... but I wanted all the other gauges to have a clean blue look. Oh... and the needle slowly changes colors along with the colors on the dial.
And yes... those are original miles
post #53 of 177 Old 05-11-2010, 09:37 AM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
That tach is sick, and your gauges look great.
I updated the original post to use the WLED-x5 bulbs instead.
-Matt
White '94 YJ Sport
UltimatE is offline
post #54 of 177 Old 05-11-2010, 09:40 AM
ncreptile
Looks good, the red would annoy my eyes personally though, most cars these days have the blue/red thing going and they always annoy my eyes.
I was thinking of doing the color blend on a gauge myself but decided at last second not to. Looks cool, for some reason it reminds me of an icee!
I love you CM <3
What goes around comes around, thats why my weapon of choice is a boomrang.
ncreptile is offline
post #55 of 177 Old 05-11-2010, 09:43 AM
Wheelman286
Yeah... it does. I don't like that it looks pink on here... it's actually blue-purple-red in person. So when I overtake... I'm GOIN' PURPLE.
And I do think it would probably be best to use a 5-WLED in the HVAC but I didn't care enough about that to buy another $4 bulb.
post #56 of 177 Old 05-11-2010, 09:46 AM
ncreptile
I paid $5 for a 360 one and mine doesnt even have a bulb option!
Left with an extra blue bulb, guess I will find a use for it elsewhere or if these ever burn out.
It reminds me of an icee machine, and one would be good right about now. Hows the weather in charlotte? Supposed to be 93f here tomorrow UHG
I love you CM <3
post #57 of 177 Old 05-11-2010, 11:43 AM
muddy93
1987 FSJ Wagoneer
Not trying to hyjack, but dose anyone know if there are any LED bulbs available that will fit the stock dash, but have regular wiring connections on the back? Basically a LED bulb that could be put in the dash(in the stock light locations), but wired to a seperate switch.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #58 of 177 Old 05-11-2010, 12:52 PM
Wheelman286
It's cold as S*** for summer here right now... like 57 or somewhere in there. I plan on putting my extras in the Blazer dash somewhere since I gotta take the damn thing apart anyways to fix the digital cluster. Might as well make sure i NEVER have to take that thing apart again.
post #59 of 177 Old 05-12-2010, 03:27 PM
bigorangeyj
has anybody used the uv blacklight bulbs yet? im considering doing that or stealing wheelmans idea.
bigorangeyj is offline
post #60 of 177 Old 05-12-2010, 06:16 PM
celticluck713
i got new head lights and had an extra bulb left over and the head lights had a small whole for a smaller bulb so i put some leds in there lol ill post pics tonight
celticluck713 is offline
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 05:33 AM
Troubleshooting water under the dash, write-up, how-to...... rustywrangler YJ Wrangler Technical Forum 62 12-27-2015 07:35 AM
YJ to CJ dash swap write up with pictures rrisher YJ Wrangler Technical Forum 171 05-11-2015 04:53 PM
Any write ups on how to swap the dash? tank07 YJ Wrangler Technical Forum 2 05-20-2009 02:55 AM
LED Dash Gauges Write-up Grewe02 TJ Wrangler Technical Forum 57 02-15-2007 12:24 PM
