L.E.D. Dash Lights Write-Up - Page 11 - JeepForum.com
post #151 of 177 Old 01-19-2014, 09:36 AM
PharaohMoe
Originally Posted by UltimatE View Post
Did you check your fuse panel to see if one blew?
No, I haven't I don't know which fuse to look for, but the radio and the turn signals work but the tech speed and the instrument cluster gauges don't light up. Tried flipping the bulbs and twisting them counter clockwise and still they won't light up.
PharaohMoe is offline
post #152 of 177 Old 01-19-2014, 12:42 PM
AmmitOsiris
AmmitOsiris's Avatar
When you turn your headlights on do all of the outside marker lights, light up? If not you have a 20 amp fuse that's blown.. Well that was my problem... Just hop under there And find the fuse that's blown and replace em
DISCLAIMER: YOUR ACTIONS ARE CURRENTLY BEING MONITORED.
AmmitOsiris is offline
post #153 of 177 Old 01-19-2014, 01:19 PM
PharaohMoe
Yea they light up, I'm not sure why those light won't light up when I turn them on. I cleaned the sockets and flipped the bulbs and still it won't turn on. Do they have a fuse just for those lights. And if u can tell me where and which fuse I'd really appreciate it.
post #154 of 177 Old 01-19-2014, 05:45 PM
PharaohMoe
It was the fuse too bad the nfc championship game is on or I would have changed it, I'll keep you posted tomorrow when I change it.
post #155 of 177 Old 01-21-2014, 05:00 PM
spare79
Column Gear Selector bulb
how do I go about replacing the bulb in the Column Gear Selector area to look like the previous post on this?
spare79 is offline
post #156 of 177 Old 06-13-2014, 08:36 AM
gfd66
OK, I just ordered all of the new LED dash bulbs from Jtech. After reading through this thread I have definitely made a great decision to replace the bulbs. I also have just gotten the white face overlay kit. Now here is the question. As I read through this I read " I did this last night' or "Got it done yesterday afternoon". I haven't taken apart a dash in a Jeep before but have done so on other vehicles. Is it really that simple to do that it can be done in a few hours?
Genius might be the ability to say a profound thing in a simple way.
Charles Bukowski
gfd66 is offline
post #157 of 177 Old 06-13-2014, 11:31 AM
Mike Romain
Well.... I have only done older ones, (helped a PO of my 89 do it) but depending on rust levels, it can be a pain. I would start oiling the hinges a few days before starting the job because the windshield has to fold forward to get at the top bolts holding the dash on. Those hinges bend Real easy! The top bars have a set screw that loosens for when you need to adjust the rake or fold the windshield. Sometimes the gasket under the windshield tears or has been glued down by a PO. Up here in the rust belt, we run into unexpected hidden rot also.
Not sure how the YJ gauge power works, but if you have the dash ungrounded and put power to everything, you can cook the fuel and temp on a CJ. I use a booster cable to go from the dash to the battery neg for testing.
Mike
Mike Romain is offline
post #158 of 177 Old 06-13-2014, 11:47 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
If you're just replacing the bulbs that illuminate the gauges and/or indicator lights, you don't need to go through all the trouble of pulling the whole dash panel as one unit.
To access the gauges, indicator light panel, HVAC control panel, or anything that lights up, the outer plastic trim pieces can be removed quickly and easily with only a phillips-head screwdriver, which exposes the bolts holding the individual devices in place underneath. These screws are all in plain sight, which makes it especially easy. Removing the individual components underneath to get at their bulbs is fairly self-explanatory once the plastic trim covers are removed. If you've disassembled the dash on other vehicles before, the YJ will probably be easier.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #159 of 177 Old 06-13-2014, 12:01 PM
hardluk
1987 YJ Wrangler
X2 on what tshark said. I have a 87 yj and did it in about 3 hrs tops. That was with some surprises behind there and cleaning everything. You don't have to drop the windshield but disconnect the battery.
hardluk is offline
post #160 of 177 Old 06-13-2014, 01:55 PM
gfd66
Nice, and thx for the helpful hints!!
Charles Bukowski
gfd66 is offline
post #161 of 177 Old 06-13-2014, 01:57 PM
Mike Romain
Yes, good to know for future, I would have been tearing the whole thing out...
Mike
post #162 of 177 Old 12-01-2014, 08:20 PM
Wheelman286
Originally Posted by Jims-87YJ View Post
So no one has done this with White face Gauges? If you have please post up how you like it and what color you are using.
I dropped off the earth for a while so I'm super late to the afterparty. Mine were White Face Gauges. I got that vinyl decal set off ebay or something and did it years ago. I dunno what happened to my pics but i may try to put them back up here.
Edit: got them back up... they're on page 4. you can sort of tell they're white but I imagine white lights would make it more noticable.
92 Wrangler 4.0 5-speed -Canyon Blue Metallic/Black Interior '00 S2000 Silverstone Metallic/Red Interior '93 S-10 Blazer Tahoe LT Black/Grey Leather Interior
Wheelman286 is offline
post #163 of 177 Old 12-03-2014, 07:02 PM
Whaty
Im curious as to which LED's you guys used for intensity purposes, im looking on superbrightleds.com and i see they have "1 led" bulbs and "5 led" bulbs, my concern would be whether or not the 5 led is too bright for dash purposes? Or if its just perfect?
Also i was looking around and i couldnt find the socket pieces the lights go into, and i think im missing one any help would be great!
thanks!
EDIT: annnnnnnd never mind i actually read the first post again and what do ya know, the answers right there! DOOH!
Whaty is offline
post #164 of 177 Old 12-03-2014, 09:30 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
^ Glad I could help.
Really, the brightness/harshness depends a lot on which color LED you choose. Red is by far the easiest on the eyes for night driving, even if you have a relatively high output ("A lot of lumens"). This is why I went with red. Even with the higher output bulbs, red is really enjoyable at night. I can guarantee that a blue bulb with lower output is more harsh to the human eye at night than a high output red bulb.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #165 of 177 Old 12-03-2014, 09:53 PM
Whaty
I am going with the green, 2 LED HP 194's and 6 LED 194's. I dont really care to mess around with the 74's unless you can sell me on them haha.
THANKS ABUNCH got them ordered!
Whaty is offline
Troubleshooting water under the dash, write-up, how-to...... rustywrangler YJ Wrangler Technical Forum 65 06-08-2017 07:44 AM
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 05:33 AM
YJ to CJ dash swap write up with pictures rrisher YJ Wrangler Technical Forum 171 05-11-2015 04:53 PM
Any write ups on how to swap the dash? tank07 YJ Wrangler Technical Forum 2 05-20-2009 02:55 AM
LED Dash Gauges Write-up Grewe02 TJ Wrangler Technical Forum 57 02-15-2007 12:24 PM
