Knuckle threads for Caliper bolts STRIPPED - JeepForum.com
post #1 of 17 Old 12-14-2008, 09:16 PM Thread Starter
sebastian22
I was doing my front brakes today and made a really STUPID move. I looked up the torque specs for the caliper bolts and it was 132 in/lbs. BUT I was a stupid idiot and set my torque wrench to 132 FT/lbs.
After a while the bolt just started spinning and when I realized what I was doing it was too late. I backed out the bolt and checked out the damage. The threads are completely stripped. I managed to thread the bolt back on and barely tighten it, but I am not comfortable driving it like that.
It was a stupid mistake and ruined an otherwise perfect day.
What are my options on fixing this? New knuckle?
95 Black YJ
sebastian22 is offline
post #2 of 17 Old 12-14-2008, 09:18 PM
Turner
re-tap it. just be very careful
--Turner--
2006 Jeep TJ
1982 Toyota Pickup 20r/22r Hybrid, 5.29s, Lockrite frt/spool rear, Longfields, Hysteer, discs, armor, dents, smiles.
1970 Ford Bronco302, dana 30, 9", 3 on the tree, show stopper.
Turner is offline
post #3 of 17 Old 12-14-2008, 09:27 PM Thread Starter
sebastian22
There is no meat left to re-tap. Cant really go a size bigger because the caliper mounting bolt has to stay the same otherwise it wont fit through the caliper sleeve.
I just found this...
http://vi.ebaydesc.com/ebaymotors/ws...dll%3FViewItem
Looks promising. Makes me feel a little better that I'm not the only idiot who stripped their caliper threads.
95 Black YJ
post #4 of 17 Old 12-14-2008, 09:29 PM
joe's_yj
joe's_yj's Avatar
maybe run a bolt with a nut and lock washer on the end?
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #5 of 17 Old 12-14-2008, 09:36 PM
Turner
Not trying to argue, but it looks like you could re-tap it with a bigger size, then drill the caliper bolt hole the same size for a larger bolt. I should have been more clear first. It can be done it would just take a little patience. If you were a little wary of doing that I would replace the entire knuckle. The eBay link didn't work for me...
--Turner--
2006 Jeep TJ
Turner is offline
post #6 of 17 Old 12-14-2008, 09:45 PM Thread Starter
sebastian22
I got you, but I dont know how I feel about drilling all the way through the caliper sleeve.
I fixed the link. Looks like it is just an insert that is threaded on the inside and outside. I guess you drill and tap the hole, thread on the insert with some loctite, and youre done.
95 Black YJ
post #7 of 17 Old 12-14-2008, 09:50 PM
Turner
Yeah it wouldn't be hard for a machine shop to do. They have nice drill press' that can center the caliper to give a perfect hole.
Not sure exactly what the item does in the eBay link cause the description is kinda vague, but it does look like it would work. For 35 bucks you could give it a try. Good luck man!
--Turner--
2006 Jeep TJ
Turner is offline
post #8 of 17 Old 12-14-2008, 09:52 PM Thread Starter
sebastian22
Looks like I found my answer. I should have searched a little more before I posted.
Here is a write up using that same "Mr. Blaine kit" from ebay.
http://www.jeepforum.com/forum/showt...aliper+threads
95 Black YJ
post #9 of 17 Old 12-14-2008, 09:52 PM
Old4X
1990 CJ7
That is a standard repair. Heli-coil is one name brand for the threaded inserts. They sell a kit for each thread size, it comes with the proper size drill, the tap and some of the threaded inserts.
It will take you longer to run out and get the kit than it will for you to fix it.
BTW, 100 foot pounds is A Lot or torque.
Old4X is offline
post #10 of 17 Old 12-14-2008, 09:56 PM
aaronc88
looks like HeliCoils
heli coils will work just make sure u do them right.
u shold be able to pick up a whold helicoil kit from and industrial store.
I dunno what u have by u but around here we have Mcmastercarr and Grainger. For grainger u need to have a bussines name and adress but i just use the place that I work for as a name. Of course with thier permission.
My work
aaronc88 is offline
post #11 of 17 Old 12-14-2008, 10:00 PM
Turner
Wow that was a pretty cool write-up! I would order that bad boy tonight.
--Turner--
2006 Jeep TJ
Turner is offline
post #12 of 17 Old 12-14-2008, 10:03 PM
themonkeyman
1987 YJ Wrangler
Make sure you put some Green lock-tite on the heli-coil external threads. The green stuff dries super hard and will prevent it from backing out when you remove the caliper bolt next time. Red will also work, just use something stronger then Blue.
themonkeyman is offline
post #13 of 17 Old 12-14-2008, 10:10 PM
RockRodHooligan
RockRodHooligan's Avatar
I've used this kit, great instructions, everything you need is in the kit. had a few issues with the shipping because a buddy used his ebay account to order it for me, that had some jacked up shipping address. mrblaine shipped another one out to me the day we figured out the problem. Very helpful!! Go for it!
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #14 of 17 Old 12-14-2008, 10:15 PM
kc8ztw
we use these kits at the place i work (they work good) and id use green lock-tite or at least red but not blue make sure you don't get it on the caliper bolts though
kc8ztw is offline
post #15 of 17 Old 12-14-2008, 10:44 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Originally Posted by hotrod_hooligan View Post
I've used this kit, great instructions, everything you need is in the kit. <more> Very helpful!! Go for it!
x2. I stripped the caliper mounting bolts on my grand cherokee's left front knuckle beginning of the year. I ordered this kit, installed the threaded inserts, and have been running it that way ever since.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
Stripped Brake Caliper Bolt at the knuckle JeepRocks86 TJ Wrangler Technical Forum 19 05-08-2010 07:59 PM
Caliper bolt stripped, how to get off? TheDragonfly TJ Wrangler Technical Forum 33 12-22-2009 08:52 AM
dana 30 steering knuckle stripped now what rip_1986 YJ Wrangler Technical Forum 11 04-21-2009 04:03 PM
Size of helicoil for caliper bolt/stripped knuckle repair? Alheim YJ Wrangler Technical Forum 8 05-23-2007 06:46 AM
Stripped Threads EricS TJ Wrangler Technical Forum 2 08-17-2003 08:45 PM
