knocking in upper right 89YJ - JeepForum.com
post #1 of 5 Old 05-01-2001, 12:32 AM Thread Starter
bigjeep39
bigjeep39's Avatar
Yah i have a 1989 Jeep YJ and there is an unusaul knocking coming somewhere from the upper right, and it almost sound like it is inside the car, but when i get on the outside the whole axle shifts places and the leaf springs twitch,any clue???
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 5 Old 05-01-2001, 12:08 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
What do you mean?? A knocking sound while driving? From the axle, front hub, drive shaft, or what?
Axles shifting and springs twitching????
When driving? What are you talking about?
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 5 Old 05-01-2001, 12:23 PM
Tonka
2015 JK Wrangler
Are the rubber bushings on your springs swaybar, track bar, etc dry rotted or cracked? If so, i would start by replacing them. Also check for broken leaves in the spring packs and worn body mount bushings. Make sure that all bolts/nuts are tight
Is your rig stock?lifted? body lift? A description of your rig would help.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 5 Old 05-01-2001, 06:59 PM Thread Starter
bigjeep39
bigjeep39's Avatar
I have a Trail Master 2inch lift i think, a 1 and 1/4 shackles, and thats about all, and 29inch wheels, it is only when i oversteer though, like allthe way left and then the minute i turn to the right it will pop back into place. I have pictures how do i place them?
1998 TJ
post #5 of 5 Old 05-23-2001, 03:04 AM
lostboy
Jack up the whole front end and shake each wheel violently .make sure the jeep is supported well.I suggest jackstands. Shake it top to bottom and then front to back. then check all the mounts for the wheels and also the engine. use a torque wrench and tighten the spring packs in a x pattern
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
89yj 2.5 to 91 4.0 help magoo1019 YJ Wrangler Technical Forum 0 07-16-2009 11:43 PM
my new 89YJ 86comanche YJ Wrangler Technical Forum 5 07-14-2008 12:21 PM
'89YJ Oil Pan Leak knightsog YJ Wrangler Technical Forum 2 06-15-2006 04:26 AM
MSD 6 on 4.2 89YJ lilredjeep YJ Wrangler Technical Forum 2 05-29-2005 03:11 PM
2.5L from a '94 YJ work in an '89YJ? jmicaho YJ Wrangler Technical Forum 5 12-07-2003 10:56 AM
