Knocking sound while accelerating - JeepForum.com
post #1 of 3 Old 04-16-2013, 08:47 PM Thread Starter
jmcgill
I finally got my 1994 Wrangler running pretty well after putting in a new fuel pump. However now I am noticing a knocking sound when I'm accelerating. The sound is really prominent when I'm using more than half throttle and only occurs around 2000 rpms. The motor idles well and runs very well aside from this knock.
I was thinking it could be something loose somewhere because its a hollow knock, but if that were the case it wouldn't appear at the same rpm range every time.
Any ideas what it could be?
An
jmcgill is offline
post #2 of 3 Old 04-17-2013, 07:58 AM
jokerchief462
Could be the way or where you hear the sound. Check for an exhaust leak at the headpipe to the manifold. It will be minor if that is it and you will find it by let it run and crawl uder and see if anything is blowing out. The sound will vary with RPM and show up to your ear at the same rpm all the time.
You could have something underneath rattling at that rpm so while underneath check all the exhaust system to include the cat heat shield.
If not exhaust check driveline u-joints for security and installation maybe a strap is loose and at that rpm it vibrates.
Best I got.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 3 Old 04-17-2013, 08:18 AM Thread Starter
jmcgill
Thanks for the help! It really doesn't sound like an internal engine problem at all. If I accelerate very leisurely, it doesn't make the sound so maybe it's something in the driveline or with engine mounts making the noise when the motor rocks under heavy acceleration on the low end.
jmcgill is offline
