knocking noise while pushing gas pedal but only when in 5th - JeepForum.com
post #1 of 6 Old 09-21-2009, 06:19 PM Thread Starter
Shellb2414
Just started out of the blue last night...doesnt matter what speed im going but as soon as I put the Jeep in 5th it begins making this knocking noise over and over, as soon as I let off the gas it stops..well you get the idea. Anyone know what this could be or how to fix it? Thanks in advance!
Shellb2414 is offline
post #2 of 6 Old 09-21-2009, 06:21 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sounds like you're losing 5th gear, a common problem with the AX-5 gearbox.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 09-22-2009, 06:05 AM Thread Starter
Shellb2414
thanks for the info! is this a fix it urself thing or take to someone thing?
post #4 of 6 Old 09-22-2009, 06:10 AM
Louie4
If you're not sure (no offense) you might want to take it to someone. If it were me, I would convert to an AX-15. I don't think the AX-5's are worth rebuilding, just my 2 cents though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #5 of 6 Old 09-22-2009, 06:11 AM
pasinbuy
What size tires do you have? If you have 33s or bigger and you have not regeared, you should not be using 5th gear
pasinbuy is offline
post #6 of 6 Old 09-22-2009, 07:02 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
This is from another thread. Read more about it here.
http://www.jeepforum.com/forum/f12/t...e-help-834764/
Max
Mean Max is offline
Hissing noise near break pedal. Stops when pedal depressed. JayMacYJ YJ Wrangler Technical Forum 3 08-15-2012 08:47 PM
Knocking Noise R947SLY TJ Wrangler Technical Forum 0 04-27-2009 04:09 AM
sucking noise when pushing gas badoosh27 TJ Wrangler Technical Forum 7 11-29-2007 11:28 AM
knocking noise Jaxbrian TJ Wrangler Technical Forum 1 01-13-2006 04:11 AM
Knocking sound coming from underneath feet... gas pedal ixl4 TJ Wrangler Technical Forum 8 04-05-2004 10:21 AM
