Knocking/ clicking sound? - JeepForum.com
post #1 of 3 Old 08-23-2017, 05:39 PM Thread Starter
Flint762
Hello have 92 with I believe an AX5 transmission. When in 1st 2nd or 3rd gear I get a noise that sound like a cross between clicking like a bad CV joint in a front wheel drive car and a card in the spokes of a bicycle. It matches engine RPM on acceleration or deceleration. When coasting with just enough gas to cause a no load there is no noise, clutch in no noise. 4th and 5th no noise. Does any one have any ideas where to start? Also when on highway coasting with a no load in 4th or 5th the is a load growl.I don't know if this is related.
Thank
Flint762
Flint762 is offline
post #2 of 3 Old 08-24-2017, 03:10 PM
mike134
Check your transmission fluid and transfer case fluid levels.
If you haven't changed the fluid in a while, just go ahead and do so. You can do the same with the differentials.
Run the old fluid through a Mr Coffee filter to see what comes out.
mike134 is offline
post #3 of 3 Old 08-24-2017, 05:13 PM Thread Starter
Flint762
Thanks Mike134
Flint762 is offline
