Knock Sensor Placement - JeepForum.com
post #1 of 13 Old 02-10-2010, 11:28 PM Thread Starter
madjeep1
I am doing a "Junkyard" TBI conversion on my 88 YJ with a 258 4.2L. I am going to run a knock sensor and need some idea on where to put it. Has anyone done this conversion and where did you install it on the block? Thanks in advance.
madjeep1 is offline
post #2 of 13 Old 02-11-2010, 10:22 AM
kloppk
Your stock setup should already have one.
See... Knock Sensor
kloppk is offline
post #3 of 13 Old 02-11-2010, 02:36 PM
markr1001
1987 YJ Wrangler
Injection Tech - Binder Planet Forums
check out the stickies on tis site, the guy is a TBI god and if you read it all you can walk through it pretty easy
markr1001 is offline
post #4 of 13 Old 02-11-2010, 03:57 PM Thread Starter
madjeep1
Thanks Kloppk, I know their is one in the intake but I wanted to put it in the block. I think it will be better to put it there.
Thanks Markr001, I have read his thread and used it along the way but he talks about their is a place to install the Knock sensor in front of the starter. On a Jeep there is no place in front of the starter. He is doing the conversion on a Scout so there prob. is one on those.
madjeep1 is offline
post #5 of 13 Old 02-11-2010, 05:15 PM
Fhajad
If the engineers put one on the intake, then it's probably one of the best places to put it.
Fhajad is offline
post #6 of 13 Old 02-12-2010, 05:41 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
IIRC the old knock sesnors were usually located in the lower area of the block on the right hand side of the engine. But they seemed to detect a 'knock' that was often just bottem end noises. The 'fix' was to wrap extra teflon tape on the knock sensor threads. I guess they decided to locate them higher up in the engine to eliminate that problem.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #7 of 13 Old 02-12-2010, 07:18 PM
jay-h
With tappet and all the other noises coming from a 4.2 block, the block is probably not where you want to put it.
The guys who designed this vehicle are not dummies. Don't second guess them without a really good reason.
jay-h is offline
post #8 of 13 Old 04-04-2014, 10:07 AM
whiskeywiz
Old thread but hoping to resurrect.
You can't go by what JEEP engineers did when you are installing a GM tbi system.
Did you get the system installed and running? I'm looking for some dizzy help!
whiskeywiz is offline
post #9 of 13 Old 04-06-2014, 08:54 AM
jay-h
In this case I would disagree. The location of the knock sensor was based on acoustics, where there was the cleanest signal. A good location would be the same whether GM or Mopar or Edelbrock system.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #10 of 13 Old 04-06-2014, 11:48 AM
whiskeywiz
Then why aren't they the same?
post #11 of 13 Old 04-06-2014, 07:50 PM
jay-h
Maybe I was unclear. The location of a knock sensor is dependent on the specific engine, not the FI system. Characteristics of the block, manifold, head etc. make some spots much better than others. During development the engineers get a good handle on the best spots, and choose one for the sensor.
If you put in a different FI, still the best spots for a sensor are unchanged.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #12 of 13 Old 04-06-2014, 08:53 PM
whiskeywiz
I thought it was specific to the sensor itself? My reasoning: a GM sensor will not work with a Mopar ECM.
post #13 of 13 Old 04-06-2014, 09:17 PM
whiskeywiz
Or is it that the sensor will not work with a diff ecm because of voltages, however its functional purpose remains the same?
Knock Sensor?????? What Do You Know???????? sknys_93 YJ Wrangler Technical Forum 10 07-30-2008 03:25 PM
Knock Sensor Location Scott 93YJ YJ Wrangler Technical Forum 2 04-24-2007 12:13 PM
Knock Sensor? Stang5lgt YJ Wrangler Technical Forum 4 11-21-2005 10:35 PM
knock sensor J_UMPER YJ Wrangler Technical Forum 2 05-30-2005 11:52 AM
knock sensor? CAJUN_YJ YJ Wrangler Technical Forum 2 10-21-2004 07:09 AM
