Knock Sensor Location - JeepForum.com
post #1 of 3 Old 04-24-2007, 08:42 AM Thread Starter
Scott 93YJ
I have a 93 YJ with the I6. I recently swaped the motor for a 2000 Cherokee Motor and need help with what to do with my knock sensor. The temp gauge does not work properly but when I move the exposed knock sensor the gage moves but does not read correct. I replaced the Coolant Temp Sensor and it reads correct via Snap-On 2550 Scanner. Any Advice? I cant find a place for the knock sensor on the 2000 motor. How can the Original Temp gauge be fixed.
Scott 93YJ is offline
post #2 of 3 Old 04-24-2007, 08:47 AM
timatoe
timatoe's Avatar
The knock sensor basically acts like a stethascope for the computer to try and adjust the timing etc. I don't believe it should have any effect on the temp guage. But, I've got the 4.2 so I could be wrong considering you're using the 4.0.
timatoe is offline
post #3 of 3 Old 04-24-2007, 12:13 PM
jfwireless
1976 CJ7
Are you trying to use your original temp gauge from the 1993 YJ I6 with the temp sensor on the 2000 Cherokee motor?? I doubt that would work.
The Knock sensor should have nothing to do with the temp sensor or gauge?
Jim
jfwireless is offline
Knock Sensor Placement madjeep1 YJ Wrangler Technical Forum 12 04-06-2014 09:17 PM
Knock Sensor?????? What Do You Know???????? sknys_93 YJ Wrangler Technical Forum 10 07-30-2008 03:25 PM
Knock Sensor? Stang5lgt YJ Wrangler Technical Forum 4 11-21-2005 10:35 PM
knock sensor J_UMPER YJ Wrangler Technical Forum 2 05-30-2005 11:52 AM
knock sensor? CAJUN_YJ YJ Wrangler Technical Forum 2 10-21-2004 07:09 AM
