-   -   Knock Sensor Location (http://www.jeepforum.com/forum/f12/knock-sensor-location-406217/)
Scott 93YJ 04-24-2007 08:42 AM
I have a 93 YJ with the I6. I recently swaped the motor for a 2000 Cherokee Motor and need help with what to do with my knock sensor. The temp gauge does not work properly but when I move the exposed knock sensor the gage moves but does not read correct. I replaced the Coolant Temp Sensor and it reads correct via Snap-On 2550 Scanner. Any Advice? I cant find a place for the knock sensor on the 2000 motor. How can the Original Temp gauge be fixed.
timatoe 04-24-2007 08:47 AM
The knock sensor basically acts like a stethascope for the computer to try and adjust the timing etc. I don't believe it should have any effect on the temp guage. But, I've got the 4.2 so I could be wrong considering you're using the 4.0.
jfwireless 04-24-2007 12:13 PM
Are you trying to use your original temp gauge from the 1993 YJ I6 with the temp sensor on the 2000 Cherokee motor?? I doubt that would work.
The Knock sensor should have nothing to do with the temp sensor or gauge?
Jim
The time now is 06:43 AM.
