knock sensor - JeepForum.com
post #1 of 3 Old 05-30-2005, 10:58 AM Thread Starter
J_UMPER
knock sensor
ok one question i have a 90 yj sport and i have a knock sensor that i have a question about ok does the knock sensor distrubt performace and if so is it safe to remove the knock sensor and how would i come to do that and would it make a differnece
J_UMPER is offline
post #2 of 3 Old 05-30-2005, 11:12 AM
JOKER4INK
I would not remove the knock sensor if that was my vehicle. It is on there for a reason of adjusting ignition timing, I beleive. I think that if you remove it you may notice an uneven idle, possible shaking and stumbling too.
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline
post #3 of 3 Old 05-30-2005, 11:52 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Yeah and you could cause other really bad things to happen as well. The computer sues that knock sensor to properly adjust everything so it all runs good. Nothing sucks worse than blowing a piston/engine 10 miles into the woods. Leave it alone. If it's acting like its bad REPLACE IT.
schitzangiggles is offline
Knock Sensor?????? What Do You Know???????? sknys_93 YJ Wrangler Technical Forum 10 07-30-2008 03:25 PM
Knock Sensor????????? Anyone Know Where It Is Located At????? Help Please sknys_93 YJ Wrangler Technical Forum 2 07-29-2008 06:43 PM
Knock Sensor Location Scott 93YJ YJ Wrangler Technical Forum 2 04-24-2007 12:13 PM
Knock Sensor? Stang5lgt YJ Wrangler Technical Forum 4 11-21-2005 10:35 PM
knock sensor? CAJUN_YJ YJ Wrangler Technical Forum 2 10-21-2004 07:09 AM
