Quantcast KMA Krawlers 93 YJ Coil Conversion - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > KMA Krawlers 93 YJ Coil Conversion
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 02-23-2010, 02:18 PM   #1
KMA Krawler
This is my first write up so bare with me as I try to document my YJ Coil Conversion. Also....first off I must thank my Klub members for all of their help with this project.(thanks Krew)
I had been thinking about this conversion for some time. I do alot of rock crawling and I had problems with one or two wheels losing contact with the rocks plus the ride was rather rough. After acquiring a donor Dana 30 and 3.5 inch RE coils (thanks Rich)I was off to a good start. I ordered most all of my builder parts from Ballistic Fabrications as well as tubing for my long/mid arms(thanks Andrew).
For this build you will need pleanty of cutoff wheels, welding wire, and grinding wheels(flapper wheels work best).
Now you need to lift your jeep from the front bumper/frame to be able to remove the front axle, don't forget to place the floor jacks on the frame around the TC skid plate(Safety First). Once in the air with the front tires off the jeep, place a jack under the axle to hold the weight and remove the leaf springs and shackles. Next disconnect the steering from the axle and the drop pitman arm. Then slide the axle out form under the jeep. Next you will need to cut off the frame brackets from the frame.
(I will write more soon, I am havng problems with my computers)
Co-Founder/ Administrator
KMA Off-Road Jeep Club
www.kmaoffroad.org
"UNANSWERED THREADS"
KMA Krawler is offline   Reply With Quote
Old 02-23-2010, 02:29 PM   #2
ZeroGravity
ZeroGravity's Avatar
This should be good
If you're trying to get your axles off the ground I've always found jacking from the axle itself works pretty well.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline   Reply With Quote
Old 02-23-2010, 09:52 PM   #3
KMA Krawler
Yeah...if your working on your axle or wanting to change your tires...but I'm removing the axle so you have to lift it from the front bumper/frame.
www.kmaoffroad.org
Old 02-24-2010, 05:01 AM   #4
YJ Nate
To each their own.
I've always found it more stable to lift from the end of the axle, remove tire, place stand under frame directly fore or aft the skid plate, lower jack, move to next tire.
So, for the front axle for example, lift axle at the front drivers wheel, place stand under frame directly in front of the skid plate, behind the front drivers spring hanger. Remove tire, lower jack, move to pass side, repeat. When you're done, you end up with your front end off the ground, no tires, on stands. Nice and stable.
ends up like this: (not the best pic.)
Anyway, not terribly important, just throwing in my 2 cents. I almost slid my jeep into a set of shelves in the garage once lifting by the bumper with a hi-lift. So i'm very conservative when it comes to supporting my jeep by anything other than its tires. :P
http://www.swbcrawler.com
YJ Nate is offline   Reply With Quote
Old 02-24-2010, 01:20 PM   #5
KMA Krawler
I hope you guys are going to let me finish this before you critique it. The reason I was lifting from the front bumper/ frame is because I am doing a coil conversion....the jacks will be in the way of my long arms so I placed the jacks under the TC skid plate where the frame is and supported the jeep under the front bumper/frame. I am doing away with the my Dana 30 and putting in a Dana 30 from an XJ.
www.kmaoffroad.org
Old 02-24-2010, 01:48 PM   #6
YJ Nate
Sorry, got carried away in my helpful nature...
Write-up away.
Old 02-24-2010, 01:51 PM   #7
TSEJEEPERS
Why are you using a Dana 30 from a XJ?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Old 02-24-2010, 01:59 PM   #8
bigorangeyj
1987 YJ Wrangler
^ ya i was wondering that too
bigorangeyj is offline   Reply With Quote
Old 02-24-2010, 02:02 PM   #9
YJ Nate
I'd bet for the high pinion. And no disconnect.
Need something with TJ-like coil buckets to make the swap simple, the XJ axle is very similar, but high pinion.
Old 02-24-2010, 02:04 PM   #10
bigorangeyj
1987 YJ Wrangler
Ooooh. makes since, kinda what i figured too.
Old 02-24-2010, 07:33 PM   #11
KMA Krawler
Thanks nate that is correct and it was free!!! I'll do more on this tomorrow. I am a firefighter and am on a 24 hour shift, when I get home tomorrow I'll post more.
www.kmaoffroad.org
Old 02-24-2010, 07:37 PM   #12
YJ Nate
Looking forward to it!
Ive got a shell of a YJ in the garage that's getting built for daily driving. I'd like to put a simple reliable coil suspension under the front. This seems perfect.
Not to mention the possibility of an upgrade for my crawler.
Old 02-24-2010, 07:38 PM   #13
msprooch
In,this should be good. Tag.
msprooch is offline   Reply With Quote
Old 02-25-2010, 07:01 PM   #14
KMA Krawler
The first two were before pictures, the third picture was how I held up my jeep while I worked on it. I also had floor jacks back by the TC skid plate.
www.kmaoffroad.org
Old 02-25-2010, 07:12 PM   #15
YJ Nate
ohhhhh you're killin me! Get into the juicy stuff!!
Glock Forum
