kinda stupid: how to bleed clutch - JeepForum.com
post #1 of 20 Old 09-10-2008, 08:56 PM Thread Starter
newtjrjrjr
I couldn't find this in the search, but how do you bleed the clutch. I've never done this on the jeep and it's way different than my other car. Thanks
newtjrjrjr is offline
post #2 of 20 Old 09-10-2008, 09:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
It's really just the same procedure as on most hydraulic clutch systems.
Use fresh brake fluid from a NEW container, verify that it is the correct fluid as called for. Fill the reservoir, have a helper pump the pedal (slowly, not rapidly) through the entire pedal travel 3-5 times & hold it down on the last pump. While your helper is holding the clutch pedal down, open the bleeder screw until all of the air/fluid is finished running out. Then tighten the bleeder while the pedal continues to be held down. Repeat this sequence until the fluid coming out of the bleeder is clean & free of any air bubbles.
Don't forget to check the level in the reservoir after each sequence or two! Running it out of fluid will cause it to suck in air, and you'll be right back to square #1.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 20 Old 09-10-2008, 09:52 PM Thread Starter
newtjrjrjr
I guess i should have been more specfic, where is the bleeder. I thought it might be on the slave cylinder but wasn't sure
post #4 of 20 Old 09-10-2008, 10:09 PM
bunkrdfool
Yes it is near the slave cylinder
USAF Security Forces. Keeping your chair safe since 2009.
bunkrdfool is offline
post #5 of 20 Old 09-10-2008, 10:12 PM
teejmcd
its a 94 its prolly has an external slave with no bleeder.... i also have a 94 and my friends 93 is different, i dont know how to bleed these though
1994 yj. lifted 4 inches locked, loaded, and armored!
Member of CORE4X4.NET
teejmcd is offline
post #6 of 20 Old 09-10-2008, 10:13 PM Thread Starter
newtjrjrjr
it does have an external slave. I had to replace it today after mine blew up, but the clutch has so much air it won't engage at all.
post #7 of 20 Old 09-11-2008, 06:31 AM
mfalik
mfalik's Avatar
I replaced the clutch master cylinder in my 94 Wrangler. It doesn't have a bleeder screw. To bleed the master cylinder you just pump the clutch pedal a bunch of times.
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
post #8 of 20 Old 09-11-2008, 07:27 AM
teejmcd
yea thats all i do pump the crap out of it and make sure its filled, don't know if it works but it sure seems like it =-p
teejmcd is offline
post #9 of 20 Old 09-11-2008, 09:40 AM
pat8942
pat8942's Avatar
Fill the master,leave the cap off and slowly push the pedal down and let it up slowly.
The air will rise and escape out of the top of the master.
When no more air or bubbles appear in the master top it off and put the cap back on.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #10 of 20 Old 09-11-2008, 10:12 AM
jazzplr
There is a bleeder (at least on my 94). It is a small allen screw on top of the slave cylinder. You need to feel around for it because it is recessed.
Hero's aren't born, they're cornered
jazzplr is offline
post #11 of 20 Old 09-11-2008, 12:28 PM Thread Starter
newtjrjrjr
the guy at auto zone said that it was auto bleeding cylinder, just pump the hell out of it till it gets normal. I've heard of this but it still sounds kinda weird to me
post #12 of 20 Old 09-11-2008, 01:05 PM
jazzplr
Good luck with that Autozone master. I went through two in one month. A buddy of mine went through 3.
jazzplr is offline
post #13 of 20 Old 09-11-2008, 07:46 PM
1Muttley
My 96 Cherokee is like that. The bleed screw is a small allen screw on the side o fthe slave cylinder. There is no bleeder fitting so you can't use a hose - it just squirts out of a tiny hole on the slave.
1Muttley is offline
post #14 of 20 Old 09-11-2008, 07:55 PM Thread Starter
newtjrjrjr
well I put the slave cylinder in and there was no bleeder on it. I opened the clutch reservoir and pumped it untill the clutch got stiff again> It bubbled for a couple mins then got to be almost normal. I think i'll have to do it again tomorrow, but it's much better.
post #15 of 20 Old 09-12-2008, 10:13 AM
teejmcd
the guy at auto zone said that it was auto bleeding cylinder, really the grand master of my auto zone said their WAS a bleeding screw on mine and im just not finding it. and he could not realize the concept that 94s and 95s have external slaves and don't have bleeders on them.... i was about to tell him ill give him 50 bucks if he could find it =-p
teejmcd is offline
How do you bleed the clutch?? Omega Man JK Wrangler Technical Forum 11 02-12-2012 07:40 PM
How to bleed clutch dokken08 YJ Wrangler Technical Forum 7 10-29-2010 08:03 AM
Clutch bleed help for a 97 TJ NOC Bulldog TJ Wrangler Technical Forum 10 02-17-2010 07:02 PM
How do you bleed the clutch? joppermann TJ Wrangler Technical Forum 7 06-20-2008 07:20 PM
clutch bleed raysnutt18 YJ Wrangler Technical Forum 9 05-16-2006 06:28 PM
