Kill switch - Page 2 - JeepForum.com
post #16 of 39 Old 08-14-2014, 08:28 AM
yj94ne
We should be careful when discussing kill switches, locations and examples in a public forum. Just a thought.
yj94ne is offline
post #17 of 39 Old 08-14-2014, 09:16 AM
Que89YJ
I am very careful. I do have a very very good kill switch setup. As you stated, discussing the need and the specifics are 2 different things.
Que89YJ is offline
post #18 of 39 Old 08-14-2014, 09:43 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Owning a 5-speed these days eliminates 85% of the punk joy riders. But ya.. keep your kill switches a secret. Or do like I did: label a toggle on the dash "Kill Switch" and rig it to blast a PA horn when switched off.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #19 of 39 Old 08-14-2014, 10:20 AM
Que89YJ
LOL awesome. Have you had any ....noise from the jeep? Cali is really bad for theft.
Que89YJ is offline
post #20 of 39 Old 08-14-2014, 10:27 AM
Luuca
Luuca's Avatar
The doberman, Rex, holds them while I aim. No issues yet, but I need to invest in a backhoe.
YJOTM never
Luuca is offline
post #21 of 39 Old 08-14-2014, 10:58 AM
Steve707
Were always having holes dug to test/repair gas lines, give me a call if you need one.
Steve707 is offline
post #22 of 39 Old 08-14-2014, 03:50 PM Thread Starter
Reno72
Thanks all, do glad to be a part of this forum. As I said electrical makes my head spin, glad I asked.
Reno72 is offline
post #23 of 39 Old 08-15-2014, 12:18 AM
Luuca
Luuca's Avatar
Electrical used to kinda scare me too. One day, a buddy who is good at it said, " think of electrical like plumbing - that can kill you. ".
Posted via my pretentious iPhone.
YJOTM never
Luuca is offline
post #24 of 39 Old 08-29-2014, 02:09 PM Thread Starter
Reno72
Just a follow up, I wired my kill switch. I found the ground wire for the fuel pump attached to the passenger side engine block by the dip stick, not by the emergency brake as many of you have. The wires run over the TC case and down the driver side rail to the gas tank. On mine the ground was brown or dark green with a yellow stripe. Thanks all for the heads up, I would have put the switch on the hot wire if not corrected by you to use the ground. I put my switch.....well let's just say I can flip it on or off wÓthout giving it away and pretty darn hard to even see.
Reno72 is offline
post #25 of 39 Old 08-29-2014, 02:38 PM
mike134
switches set to kill!
mike134 is offline
post #26 of 39 Old 08-29-2014, 06:32 PM
Mambo_Dave
... Or do like I did: label a toggle on the dash "Kill Switch" and rig it to blast a PA horn when switched off.
LOL.
Good idea!
Mambo_Dave is offline
post #27 of 39 Old 08-31-2014, 03:52 PM
Mambo_Dave
Originally Posted by Mike Romain View Post
Is the ground not right there on the e-brake frame?
I looked at both the plate up under and the actual e-brake. I did see an orange black near the e-brake pedal going to what seemed to be a relay, but didn't see it attaching to either for a ground.
Am I missing my 1991 fuel pump ground somewhere here? The red arrow points to the orange black going into some relay.
Under the Jeep: no wires that I saw
E-brake:
post #28 of 39 Old 08-31-2014, 03:59 PM
Luuca
Luuca's Avatar
E-brake:
The ground on the "e-brake frame" he was talking about is inside the cab, just above the e-brake pedal, along the door opening.
YJOTM never
Luuca is offline
post #29 of 39 Old 08-31-2014, 05:22 PM
Mambo_Dave
Thank you. I will look again.
post #30 of 39 Old 08-31-2014, 05:30 PM Thread Starter
Reno72
There has to be wires coming from your fuel tank, look on the inside frame rail.
The orange black was my hot wire to the pump. I opened up the wire cover along the frame rail going to the fuel tank. I had three wires, the orange/black hot to pump, the dark green/yellow as ground and a tan wire which I assume is the fuel gage. Follow those wires and see where they go, mine crossed over the TC where the ground wire came out by the firewall and attached to the engine block. If yours goes all the way up the driver side it may be like those who's ground is on the E brake bracket.
Reno72 is offline
