Kill switch - JeepForum.com
post #1 of 39 Old 08-12-2014, 09:30 PM Thread Starter
Reno72
Kill switch
So I have found the orange/black power wire that runs to the fuel pump under the frame. I'm thinking of just splitting this wire to a hidden toggle switch by the rear roll bar. Will this work as a simple kill switch to cut power to the fuel pump? Or is there other problems that will surface? Sorry but electrical stuff makes my head spin as I found with my interior lights which run on a ground switch.
Reno72 is offline
post #2 of 39 Old 08-13-2014, 09:06 AM
kahanabob
don't know why it would not work. just get a good toggle switch.
kahanabob is offline
post #3 of 39 Old 08-13-2014, 09:16 AM
jbolty
jbolty's Avatar
That will work fine.
A kill switch needs to be hidden, but still easy for your to get to. It also needs to not be obvious what you're doing if someone happens to be watching you get in, start and drive off.
jbolty is offline
post #4 of 39 Old 08-13-2014, 10:25 AM
yj94ne
interrupt the neg, not the pos
yj94ne is offline
post #5 of 39 Old 08-13-2014, 12:52 PM
Que89YJ
Yep. x1000. Never mess with power You are opening yourself up for a lot of issues. Find the ground and use it.
Que89YJ is offline
post #6 of 39 Old 08-13-2014, 01:08 PM
Mike Romain
Is the ground not right there on the e-brake frame?
Mike
Mike Romain is offline
post #7 of 39 Old 08-13-2014, 02:07 PM
Que89YJ
It should be.
Que89YJ is offline
post #8 of 39 Old 08-13-2014, 03:40 PM
Code3_jace
The negative runs to a bolt on my E-brake (at least it does on mine). Ive had the bolt rattle loose and I've lost fuel delivery mid freeway one time... Perfect place for a kill switch to be wired in. In-fact, thanks for the idea~!!!
Code3_jace is offline
post #9 of 39 Old 08-13-2014, 05:39 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Some of us non-smoking people use that ground wire and the factory cig lighter as a switch. Press it in to run. I also have a cig adaptor inside my center console for powering my phone.
No one will notice a driver pushing in the cig lighter... and tossing the cig lighter into your backpack or cargo pocket helps to ensure the jeep is there when you return.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #10 of 39 Old 08-13-2014, 07:30 PM
TomYJ
Not to go way off topic....how necessary is a kill switch (scale 1 to 10, with 10 being a must)?
TomYJ is offline
post #11 of 39 Old 08-13-2014, 07:39 PM
NonRubicon
Not necessary, but it's an additional layer of deterrence.
Provides a little peace of mind knowing that someone isn't going to drive your rig away (unless they find/bypass your kill switch). However, a kill switch can't stop a tow rig such like those that repo men use. The determined and prepared thief will take what he wants.
NonRubicon is offline
post #12 of 39 Old 08-13-2014, 07:41 PM
Mike Romain
Nice Jeeps are a high theft item. Depending on where you live or travel to... your call. I have one in my Renegade and my CJ7 Laredo.
Mike
post #13 of 39 Old 08-13-2014, 07:58 PM
Que89YJ
It depends on if you want a thief to drive or push your jeep when he tries to steal it.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #14 of 39 Old 08-13-2014, 07:59 PM
Que89YJ
Anything with the Saginaw steering column can be stolen with a screw driver and hammer 30 sec.
Fault codes:
No Start:
Que89YJ is offline
post #15 of 39 Old 08-13-2014, 08:36 PM
TomYJ
Adding to the mod list - thanks
TomYJ is offline
