key lock clip removal - JeepForum.com
post #1 of 4 Old 02-24-2013, 04:43 PM Thread Starter
bigboss408
how do you remove the key switch clip and key warnimg buzzer contacts
it says in the chilton book to turn the switch to the on position and pull it out i tried but no matter what i do it wont come out and they also sy to use a thin screw driver to remove switch clip? i tried a thin screw driver a dental pick and there is no way i could get it out,
what is it im doing wrong, had to reassemble the whole thing because i have to go to work tomorrow
bigboss408 is offline
post #2 of 4 Old 02-24-2013, 04:54 PM
booboowv77
Some have a screw and some have a push style clip in them. Here is the write up I used
http://www.epiccomputer.com/dale/jee...tilt/tilt.html
Once you find it it will pretty much just fall out (at least mine did)
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #3 of 4 Old 02-24-2013, 05:30 PM Thread Starter
bigboss408
so its either a scrwe or clip,is it ever both? i tried the buzzer clip they way they said i pulled with a needle nose pliers,and it wont budge im afraid to break it
post #4 of 4 Old 02-25-2013, 07:20 AM
Que89YJ
Did you look at his post. It has a pic guide to pulling it apart.
Que89YJ is online now
