Keep or remove charcoal canister? - Page 2 - JeepForum.com
post #16 of 23 Old 08-09-2009, 06:28 PM
navman
The only thing the charcoal cannister does is remove the chance of gas fumes from building up. It has no effect good or bad on how the engine runs, so why bother removing it.
95 YJ 5.0 linked etc
navman is offline
post #17 of 23 Old 08-09-2009, 06:34 PM
fyrdriver
1983 CJ7
I still have mine, but always wondered, are they sealed for water crossings/mud?
Firefighters Jeep Club
fyrdriver is offline
post #18 of 23 Old 08-09-2009, 08:23 PM
levergun
1979 CJ5
Not really. Mine isn't connected any more after my 4.0 conversion. I haven't had any issues at all. It's a emission control device so it doesn't affect drive ability anyway.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #19 of 23 Old 08-09-2009, 08:24 PM
levergun
1979 CJ5
I needed a place to put my onboard air tank- lets see- air tank, or canister- easy answer for me.
levergun is offline
post #20 of 23 Old 08-09-2009, 08:40 PM
River Ryder
I didn't seem to get water in mine. The parking lot at work flooded alot. So water crossing was a regular occurrence. I used to push the dumpsters back to the dock all the time when they floated away.
95 Rio Grande 4.0L conversion, T70, Electric Fan, Air Bag suspension, 4 link F/R, 1/2 ton dodge axles and 35x12.5 15. 4 wheel disc brakes. Frame Off restoration in progress. (so many pieces)
1997 Cherokee Sport 2 door 5spd. 4.0L H.O. Cold air Intake, Flow master 40. (Daily Driver) 2.5" lift
River Ryder is offline
post #21 of 23 Old 08-09-2009, 09:02 PM
green89yj
I still didn't get my stuff hooked up. Where are the PCV and CCV supposed to go? CCV goes to base of the carb to be burnt off and PCV goes to the canister right? Maybe?
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #22 of 23 Old 12-14-2010, 11:18 AM
AidanMullen
Guys,
I have been having fits after installing a new motor and Weber 32/36 Carb conversion from JCWhitney. I can't seem to get it to run right no matter what I do and there are SO many opinions on how to hook up vacuum advance. Red Line told me to use the ported (EGR) valve on the carb, and to cap the other vacuum port, but I've heard from others that Weber says to NOT use the vacuum advance at all and run the timing up to 12 DBTDC. My Jeep has no smog parts except the charcoal canister. The EGR is capped and will be coming out when I can find a plate for the manifold. There is a 3/8" ID vacuum line coming from what looks to be the bowl vent high on the front of the carb base, going to the charcoal canister. The disk shaped Valve(?) on the vent to the far right on the canister seems to be missing it's top. Today, I disconnected the bowl vent line from the canister to the carb, and the engine perked up with air coming in. Is this normal? If I plug it, I'm right back to rough idle. Can I run a line into the air cleaner assembly feeding this vent, or am I just loosing my mind here? PLEASE somebody help. I'm just learning, but nothing I do seems to work!!!!
Thanks!
AidanMullen is offline
post #23 of 23 Old 02-11-2013, 08:22 PM
elomsjeep
Im in the same boat. Tmrw ill take a pic and post it maybe something is wrong
elomsjeep is offline
Charcoal canister? Redskybri YJ Wrangler Technical Forum 11 02-20-2008 10:37 AM
Charcoal Canister in 98 TJ splitz TJ Wrangler Technical Forum 0 04-09-2007 01:09 PM
charcoal canister toates89 YJ Wrangler Technical Forum 12 06-23-2006 06:00 PM
Charcoal canister TSEJEEPERS YJ Wrangler Technical Forum 2 12-21-2004 12:42 PM
Charcoal canister todnshay YJ Wrangler Technical Forum 3 10-01-2003 08:51 AM
