Keep or remove charcoal canister? - JeepForum.com
post #1 of 23 Old 03-28-2009, 01:24 PM Thread Starter
gettrdone
gettrdone's Avatar
I had a very bad problem with oil going back into my intake so I installed a breather on the valve cover, I then was going to simply change my air filter when I remembered I had an intake from my previous '04 wrangler. I had to hack it a little to make it work but it saved me a few bucks on buying a new filter. However I now no longer have a bung for the charcoal canister hose. I have since caped it off and have not noticed a fuel smell or any decrease in mileage. Is there any reason other than emissions to keep it? By the way I am in an area that does not have emissions testing, other than to check for a catalytic converter.
Tom
'92 YJ 4.0L, 32RH, 3" body lift, RC 4" lift,
35x12.50 MTs, Black D Window Steelies, TJ rear bumper, TJ flares, homemade "stubby" front bumper, CJ tailgate, Supertop, D30 perma-lok.
gettrdone is offline
post #2 of 23 Old 03-28-2009, 02:19 PM
WellingtonPFunk
I'd say emissions is a pretty good reason to keep it on.
But when I bought my '88 YJ the previous owner had removed the charcoal canister (along with a bunch of other botched "repairs") and the thing stank up the garage with raw fuel smell when parked overnight. If parked for more than about 2 days I'd start to smell it in the basement next to the garage.
WellingtonPFunk is offline
post #3 of 23 Old 03-28-2009, 04:33 PM
bigh20rnr
bigh20rnr's Avatar
1987 YJ Wrangler
Yeah I agree with keeping the charcoal canister even if you get rid of everything else, it seems to keep the fumes down.
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub
"Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!!
bigh20rnr is offline
post #4 of 23 Old 03-28-2009, 04:36 PM
green89yj
I don't even think mine is connected but I don't know. Isn't there supposed to be a line that goes back to the tank?
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #5 of 23 Old 03-28-2009, 06:39 PM
speepdaedeesi
charcoal canister is on the left side when looking at the motor from the front bumper right?
right below the battery?
speepdaedeesi is offline
post #6 of 23 Old 03-28-2009, 06:49 PM
green89yj
No. I am pretty sure that is a vacuum reservoir. The charcoal canister is on the other side under all the brake stuff. Down by the radiator overflow bottle and the washer fluid reservoir bottle. Near where the ICM is located.
post #7 of 23 Old 03-28-2009, 07:01 PM
Nates93yj
Nates93yj's Avatar
ding ding ding.......we have a winner. right below the brake stuff like said above
NATE
2003 GMC 2500 Duramax
2004 Jeep Wrangler Columbia Edition
1993 Jeep Wrangler
SOLD
Nates93yj is offline
post #8 of 23 Old 03-28-2009, 07:23 PM
krd
i removed my canister, no smell at all.
258 str.6 w/1" mml, nuttered, 32/36 weber carb, hei, TF-999 w/hurst floor shift, np231 w/aa slip yoke eliminator, jks quick discos, 3-1/2" fabtech, 1" bl, MORE 5/8" boomerangs front and rear, dana 44's front and rear 4.56 locked, herculined tub and family style roll bar, jks u-bolt plates, xenon flat fenders, rrc pre-runner, custom built rear bumper, Gen-right rock sliders and hood louvers, 35" mtz micky t's, bullet proof high steer, bestop soft top w/tinted windows.
1988 yj
2007 gmc 2500 crew cab
2009 volvo xc70 turbo
1988 porsche 911
krd is offline
post #9 of 23 Old 03-28-2009, 09:44 PM
green89yj
yes. I got one right. : I have been messing with some emissions stuff and I am thinking about ripping a lot of it out. The PO has a bunch of stuff doubled back and corked up with bolts and such.
post #10 of 23 Old 03-29-2009, 12:37 AM
ayerightaye
Ive had mine out for a couple years now and occasionally will get a wiff. Hasnt affected anything else though
KING OF THE DRIVEWAY
YJ '89 4.2 UNDER constant CONSTRUCTION
"But I thought you fixed it last week!!"
ayerightaye is offline
post #11 of 23 Old 03-29-2009, 07:53 AM
buckshot500
I found the charcoal canister, & the rollover valve need to be properly connected or I get the fumes at the back of the jeep.
Fuel vapors are flammable, mmm-kay?
If you decide to reconnect it all. Then these diagrams might be helpful.
Also the rollover valve & it's related rubber connector are available from the jeep dealer for YJ's.
The white plastic part is the rollover valve p/n j5360058. $10.00 at the dealer. Usually these are just fine & can be re used. The black rubber part is the connector. p/n 53004047 is about $30.00 at the dealer. These are usually dry rotted. There is supposed to be a plastic clip, which holds the metal line to the forward bulkhead of the compartment that it lives in.
buckshot500 is offline
post #12 of 23 Old 04-04-2009, 11:04 PM
green89yj
sweet. thanks man. those diagrams are awesome. I wanna get some of that hooked back up. So the rollover check valve goes to where? and the carb bowl vent is the one just below that right? I have the carter so we might be speaking two different languages here.
post #13 of 23 Old 08-09-2009, 02:27 PM
jesseleikerjeep
Anyone have a similar diagram/photo combo of the 2.5L so I can figure out my 1991. I know nothing of these motors and want to make sure everything is straight when I start tearing and ripping. Trial and Error is ok, but this is my DD.....
-Jesse
jesseleikerjeep is offline
post #14 of 23 Old 08-09-2009, 05:43 PM
DriveTooMuch
Can we get a diagram on how to clean it too please.
DriveTooMuch is offline
post #15 of 23 Old 08-09-2009, 06:07 PM
tclaremont
2014 JK Wrangler
Huh. I am still trying to figure out how to uninstall 200k miles of dirt.
Tim C.
Rochester, NY
tclaremont is offline
Charcoal canister? Redskybri YJ Wrangler Technical Forum 11 02-20-2008 10:37 AM
Charcoal Canister in 98 TJ splitz TJ Wrangler Technical Forum 0 04-09-2007 01:09 PM
charcoal canister toates89 YJ Wrangler Technical Forum 12 06-23-2006 06:00 PM
Charcoal canister TSEJEEPERS YJ Wrangler Technical Forum 2 12-21-2004 12:42 PM
Charcoal canister todnshay YJ Wrangler Technical Forum 3 10-01-2003 08:51 AM
