K&N filter conversion - JeepForum.com
post #1 of 5 Old 11-25-2001, 09:56 PM Thread Starter
mde
I own a 89' YJ, however, I am replacing the motor with a rebuilt 87' 258. With other performance mods such as a 4.0L head swap, HEI and MSD ignition control. I would like to build a conical K&N filter design for my YJ. But without luck, I cannot figure out the complex vacum system assiciated with these engines.
Does anyone have any tips or suggestions which I can use to build a tube style K&N filter design for my Jeep? Any help would be greatly appreciated.
Cheers
89' YJ
AMC 258, all mods
7" SOA BF 35" mud terrain
mde is offline
post #2 of 5 Old 11-25-2001, 11:12 PM
reckless
i made one for mine out of pvc pipe and some copper fittings. I have pictures but they're on my roomates computer and can't get to them now, maybe later.
reckless is offline
post #3 of 5 Old 11-26-2001, 06:23 AM
glm 87 wrangler
are u running FI or carb?If you have a carb i may be able to help a little on the vac lines
let me know.Later,Gary
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #4 of 5 Old 11-26-2001, 10:03 AM Thread Starter
mde
It's carburated by the Carter 2 barell. The ECM module is bypassed on my Jeep.
Are most of the hosses running in and out of the air filter assembly essential elements for running this engine?
Some of them are easy enough to relocate, however, there are others such as temperature sensors which I do not think I need.
89' YJ
AMC 258, all mods
mde is offline
post #5 of 5 Old 12-06-2001, 08:27 PM
YJRomeo
i have a write up on www.jeepyj.com, under project how-to's if you have any questions email me @ romeofoever@hotmail.com
92 YJ 4.0L w/ 2.5" rancho springs, 1.5" shackles, 3" body, pacesetter headers, flowmaster exhaust, Homemade K&N cold air intake system, 4.11's, lockrights,33x12.5 X-terrains on 15x8 black rockcrawlers. homemade discos... coming soon homemade gas shock hood lift. done everything myself. (not bad for 19 yrs old)
YJRomeo is offline
synthetic oil filter vs regular oil filter MacK JK Wrangler Technical Forum 2 10-31-2009 10:09 PM
paper air filter with pre-filter fish4life TJ Wrangler Technical Forum 5 05-28-2008 04:47 AM
Air Filter Oil Filter whats the difference? LlamaJeep YJ Wrangler Technical Forum 9 03-15-2008 10:52 AM
K&N Square Stock Filter or Round K&N filter??? SupaJosh TJ Wrangler Technical Forum 9 09-13-2005 04:59 PM
Fram Disposable Air Filter (Same Part Number Different Filter) julietkilo TJ Wrangler Technical Forum 7 07-15-2005 09:02 PM
