Just slide the fork over and walk away? - JeepForum.com
post #1 of 26 Old 04-08-2014, 05:50 AM Thread Starter
Rproject
1987 YJ Wrangler
If you slide the fork towards the pumpkin and cap the vacuum lines can you just walk away from it and always have the shaft engaged? Since the system needs vacuum to disengage, the fork should stay engaged - right?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread: http://www.jeepforum.com/forum/f22/r...hread-2164793/
Rproject is offline
post #2 of 26 Old 04-08-2014, 06:35 AM
rogerv
rogerv's Avatar
Slide the fork over and reinstall the e-clip so that it won't slide back, then walk away. No more getting caught in a snow storm and having to lay in the snow to do it. Ask me how I know.
If it's not broke- modify it, so it won't break
rogerv is offline
post #3 of 26 Old 04-08-2014, 06:40 AM Thread Starter
Rproject
1987 YJ Wrangler
What e-clip? I took off the cover on the 95 axle I picked up and there was no clip on either side of the donut. Just the 2 shafts, the donut ring that joins them and the fork. When we pulled the outer shaft the ring fell right out.
1996 White ZJ
Rproject is offline
post #4 of 26 Old 04-08-2014, 07:35 AM
XJ93
There are two e-clips, one on either side of the shift fork holding it in place on the vacuum motor shaft.
XJ93 is offline
post #5 of 26 Old 04-08-2014, 07:41 AM Thread Starter
Rproject
1987 YJ Wrangler
Ah, OK. I may need to crack it open again and take a second look at it. So the process would be to slide the fork towards the pumpkin, remove the e-clip from the pumpkin side of the fork and reinstall it on the passenger's side of the fork. Correct?
1996 White ZJ
Rproject is offline
post #6 of 26 Old 04-08-2014, 07:43 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
These clips
Luck Favours The Prepared
Anticanman is offline
post #7 of 26 Old 04-08-2014, 07:50 AM Thread Starter
Rproject
1987 YJ Wrangler
These clips
AHHHH! I see said the blind man as he picked up his hammer and saw.
So I pull the e-clip at the fork, slide the fork over and reinstall. That keeps the fork moved over and the axle shafts permanently engaged. Makes total sense.
Since my rig is not a daily driver, and I have a lunchbox locker in the front already, I see no reason to fiddle fart with the vacuum system. I'm going to slide the fork over and be done with it. No posi, no vacuum, no wondering if the system will fail down the road.
1996 White ZJ
Rproject is offline
post #8 of 26 Old 04-08-2014, 09:04 AM
Lemoore-on
Dont forget to slide the coller over on the shafts as well.
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #9 of 26 Old 04-08-2014, 09:30 AM Thread Starter
Rproject
1987 YJ Wrangler
Yup. Already did that part.
1996 White ZJ
Rproject is offline
post #10 of 26 Old 04-08-2014, 10:48 AM
bpounds
bpounds's Avatar
Originally Posted by Rproject View Post
If you slide the fork towards the pumpkin and cap the vacuum lines can you just walk away from it...
I would drive away, if it were me.
Just remember you can't tow it flat with that mod.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #11 of 26 Old 04-08-2014, 11:11 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You can with a true neutral plate though.
post #12 of 26 Old 04-08-2014, 11:11 AM
EABiker
Your mileage may vary, (not literally !).
It may not be so simple; if you have an unbalanced front drive shaft, (like I do), you cannot just lock the fork over or you will get bad vibes at highway speed.
EABiker is offline
post #13 of 26 Old 04-08-2014, 11:35 AM
bpounds
bpounds's Avatar
Yes. Although then this is no longer as simple as walking, or driving, away.
I just like to mention the towing thing because I tow mine a lot, so to me it is an important detail.
Bill
bpounds is offline
post #14 of 26 Old 04-08-2014, 11:39 AM Thread Starter
Rproject
1987 YJ Wrangler
Flat towing is not an issue for me. I have a throne for my rig to ascend when I go any decent distance.
1996 White ZJ
Rproject is offline
post #15 of 26 Old 04-08-2014, 01:58 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Glad you mentioned it. A lot of people read these threads and get some help. I like to cover other aspects before they break things.
