Just got my YJ Mirror Movers..... - JeepForum.com
post #1 of 9 Old 04-27-2011, 03:31 PM Thread Starter
alexs93
.....and I can't remove the windshield bolts....it's not that the head is stripped (damned torx), but I have them all loose....they just keep spinning.....Anybody else have that problem? and solution?
alexs93 is offline
post #2 of 9 Old 04-27-2011, 03:55 PM
Nibbley15
Did you find the nuts on the inside? There are plenty of threads talking about this.
http://www.jeepforum.com/forum/f12/b...inges-1145255/
http://www.jeepforum.com/forum/f12/y...-hinge-936347/
http://www.jeepforum.com/forum/f12/t...emoval-930006/
http://www.jeepforum.com/forum/f12/w...emoval-754187/
This should get ya a good start! Good luck, they look to be a big PITA
Nibbley15 is offline
post #3 of 9 Old 04-27-2011, 05:38 PM
tmontana
If you drill them out, you can have the brackets installed with new bolts in about 30 minutes. I used 3/8 by 1inch bolts with self locking nuts with 9/16 heads.
tmontana is offline
post #4 of 9 Old 04-27-2011, 07:13 PM
50rck
I had to remove my dash to get to the nuts on the inside. I had to cut away all the sealer they use. Its all over in there.
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
post #5 of 9 Old 04-28-2011, 06:32 AM
Que89YJ
They use locktite on those. You need to applly heat before you try and take them out.
Que89YJ is online now
post #6 of 9 Old 04-28-2011, 06:38 AM
CrawlingForward
Man, that was a PITA for what seemed like it was going to be a minor modification, ha ha.
It turns out to be a good project, though. Taking off the dash definitely makes it faster and easier and drilling out the Torx bolts officially makes you a YJ owner, ha ha ha.
I wouldn't even bother with trying to take off the Torx and/or reuse them. Just drill them out and use a good hex bolt and nut to replace them.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #7 of 9 Old 04-28-2011, 06:53 AM
superj
i have had some for a few months but those damn bolts are such a pain i keep putting off installing them
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #8 of 9 Old 06-04-2011, 09:06 PM
mannyj
i think im just gonna get the mirrors that bolt into the door hinge and call it good and just ship the relocation brackets back or sell them to someone who has a lot more time
mannyj is offline
post #9 of 9 Old 06-05-2011, 07:04 PM
kojak70
I had a time with my 89. My sons 94 seemed to be infinitely easier. There is just more room in there to move. I ended up finding rust under windshield and pulled the entire dash and replaced it all. It took about 2 months working in my spare time. What a job just to replace 4 bolts!
kojak70 is offline
Mirror Movers negreac TJ Wrangler Technical Forum 25 05-25-2007 12:19 PM
Mirror Movers JohnBlaze TJ Wrangler Technical Forum 13 04-04-2006 02:44 AM
Mirror Movers??? 55willystruck TJ Wrangler Technical Forum 5 07-27-2005 05:01 PM
mirror movers truckie453 TJ Wrangler Technical Forum 5 02-26-2005 08:40 PM
Mirror Movers tommytj TJ Wrangler Technical Forum 8 09-18-2003 07:48 PM
