Just got my first jeep 1993 yj sahara - JeepForum.com
post #1 of 3 Old 07-25-2011, 08:38 PM Thread Starter
Flint007
I just got my jeep about 2 weeks ago and I am slowly fixing it. I noticed a couple of days ago that's my front wheel On the drivers side was making noise and I did some research to try to find what was wrong with it but non of the possible problems were it. So I had my dad ( 1983 cj7 owner) turn the steering while it was jacked up and I turned the wheel. What I discovered was that the tire is rubbing on the leaf spring. What can I do to fix this problem do I need to do something to the tie rod?
Flint007 is offline
post #2 of 3 Old 07-25-2011, 09:04 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
If you look on the knuckles, right near the lower ball joint, you'll see a bolt sticking out with a nut at the base of the bolt. These are your steering stops. The nut is welded onto the bolt, so just remove it as one piece. Install a washer (or washers, as needed) under the nut until there is clearance between the tire & leaf spring while turning.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 3 Old 07-26-2011, 04:03 AM Thread Starter
Flint007
Thanks I'll give that a try
Flint007 is offline
Soft Top recommendation for 1993 YJ Sahara weerwolv YJ Wrangler Technical Forum 11 02-27-2011 08:22 PM
Made an intake for my 1993 Sahara 4.0 - here's what I did Tobey YJ Wrangler Technical Forum 4 03-29-2009 06:17 PM
Need help ! 1993 Wrangler Sahara Clutch loggy YJ Wrangler Technical Forum 0 02-04-2008 10:09 AM
Question on 1993 Sahara Springs Ksplayland YJ Wrangler Technical Forum 7 12-04-2007 06:56 AM
Just picked up a 1993 Sahara for $1500!! Bigbadwolf54 YJ Wrangler Technical Forum 22 05-28-2007 05:46 AM
