Just completed heater upgrade on my YJ - JeepForum.com
post #1 of 6 Old 06-01-2005, 11:19 AM Thread Starter
riverman
Hey all. I just completed the blazer heater blower upgrade on my 1990 YJ and for the money, its the best upgrade out there. The correct part number is siemens PM102. Dont get the 105. Its too long. The 102 bolted right up and required no shimming. The only thing that was even remotely time consuming was making the hole in the firewall approx. three and a quarter inches. No big deal though. I used a scroll saw and a dremmel tool with a high speed cutting bit. It looks like a factory job and WHAT A DIFFERENCE!!! This blower motor puts out as much hot air on low as the original one did on high! I advise anyone to do this upgrade. If you need any help, let me know. Oh yeah the motor was about 20 bucks at Autozone and guaranteed for life. Another thing, if you plan on doing this swap, take the little foam seal from around your original motor and stretch it around the new one. Its tight but it will fit. This will help it seal to the firewall. then once its installed, its a good idea to run some Black silicone around it.
riverman is offline
post #2 of 6 Old 06-01-2005, 03:26 PM
JOKER4INK
If you have pictures or anything that would help us out with that mod, we would all appreciate it! Thanks!
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline
post #3 of 6 Old 06-01-2005, 06:20 PM
Alheim
whoa, neat - didn't know that was possible.. when/if my heat ever goes, i'll definitely be hooking that up..
'95 YJ 123bhp 4-banger powerhouse.
UPDATE: 2.5L ENGINE RETIRED; she was still running strong at 212,000mi.
4.0 swap in progress.
Alheim is offline
post #4 of 6 Old 06-01-2005, 06:36 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
heat? what's that? i thought that only worked when the sun was out.....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #5 of 6 Old 06-02-2005, 08:04 AM Thread Starter
riverman
I dont have any pics but you can do a search on the net. Just type in "Jeep heater upgrade". One guy has some pics posted on the subject. One tells you to buy the PM 105 but you actually need the 102. Or at least thats what I discovered after researching. Its really easy to do and you dont have to be a master mechanic to do this. Trust me, its well worth it and simple.
riverman is offline
post #6 of 6 Old 06-02-2005, 10:04 AM
acejeep
Has anybody changed those idiotic Jeep vacuum heater controls to manual controls ?
Knowledge is what we get from reading the directions.
Experience is what we receive from not reading the directions.
acejeep is offline
Heater upgrade (amazing) 92wrangler YJ Wrangler Technical Forum 22 08-20-2009 11:14 PM
4 Cyl Exhaust Upgrade Completed Thug Nasty TJ Wrangler Technical Forum 8 01-11-2007 03:33 PM
Heater upgrade? Millinski YJ Wrangler Technical Forum 3 11-26-2005 01:45 PM
HEI Upgrade completed.... Now What? Slider_88YJ YJ Wrangler Technical Forum 3 03-14-2003 05:37 AM
Heater Control Upgrade...is it possible? SgtSki TJ Wrangler Technical Forum 10 09-11-2002 10:29 PM
