Just bought a sad old '94 YJ for my son ..help? - Page 5 - JeepForum.com
post #61 of 227 Old 12-25-2013, 06:55 PM Thread Starter
Jeep4MyKid
Ahhhh! Major emergency! I pushed the parking brake pedal just to see if it worked, and it did. I pulled the release and it made a loud sound, so i thought that was the brake disengaging, but apparently not. Now the car only starts sometimes, and when it does, it won't go forward, only goes reverse what the heck have I done?!
Jeep4MyKid is offline
post #62 of 227 Old 12-25-2013, 07:27 PM
linusb
Does the parking break pedal feel normal when you push it?
Do you have stick shift or automatic?
I think you might be panicking. The parking release does make a pretty loud noise when released.
Releasing break wouldn't have an effect on engine and transmission. You might have a weird electrical issue shorting something out causing problems starting but the vehicle moving backward and not forward would not be related to any of that.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #63 of 227 Old 12-25-2013, 07:30 PM
Dingo1033
Could the rear shoes on the brakes be frozen? Who knows if the previous owner every used the Ebrake. I always leave mine in gear cause my Ebrake is busted. Just a thought.
"I may not change the world, but I'll damn sure leave a scar"
Dingo1033 is offline
post #64 of 227 Old 12-25-2013, 07:30 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
What he said. ^^^
Edit: Both of them.
Michaelgoesrawr is offline
post #65 of 227 Old 12-25-2013, 07:43 PM
linusb
You are doing what you should be - you're getting to know your jeep. It takes time.
linusb is offline
post #66 of 227 Old 12-25-2013, 09:50 PM Thread Starter
Jeep4MyKid
I've learned it a little bit more, but I still can't get it to drive forward! The jeep worked fine until the parking brake incident. It's automatic just for future reference. So now it only starts if I put it in neutral first, otherwise it doesn't do anything and the brake light turns on. When I DO get it started, it only goes in reverse, never forward unless I really give it some gas, which leads me to believe the brake is still engaged. Any ideas at all? I can't drive it at all since it doesn't go forward and I really don't want to get it towed
post #67 of 227 Old 12-25-2013, 10:13 PM
linusb
It does sound like the parking brake is stuck. Though my parking break sure isn't good enough to prevent me from moving. Do you know anyone who is good with drum brakes?
Your jeep only starting in neutral is a mystery. Describe exactly what it does when in park when you turn the key for it to start.
Also, check for engine codes. Turn the key on and off three consecutive times and leave it on the third time. Your check engine light will flash. If there are no codes it will blink five times quickly, pause and blink five times again. That is code 55 and means its the end of the report. If there are bad sensors or whatever, keep track of the flashes and they correspond to a two digit number. Google them if it gives you any codes beside 55.
linusb is offline
post #68 of 227 Old 12-25-2013, 10:18 PM
Dingo1033
Pop the rear wheels and see if you can get the drums off. If you can't get the drums off There's an inspection hole that's on the back side of the backing plate. Usually has an oval rubber plug in it. Pull that plug and use a flat head screw driver abd back the shoes off a bit.
I'll bet when you engaged that parking break the shoes froze in the "on position"
Aren't Jeeps fun :-)
post #69 of 227 Old 12-25-2013, 10:25 PM
Xpress
Welcome to the madness that is an older Jeep. Trust me, I knew next to nothing about Jeeps when I first signed up here 3 whole years ago. Now I'm in the middle of tearing my Jeep down to the frame and rebuilding it the way I want it. Prepare to learn a lot, because this forum is a literal endless supply of information. So many knowledgeable guys here that jump on board right off the bat to help out.
And your mom did you a favor, those shiny new plastic Jeeps are nothing but a shiny HotWheels toy. These older Jeeps have a lot more going for them, not to mention the aftermarket supply is endless. Front to back, top to bottom, if there's something you want, chances are someone makes it in a bolt on variety. And even if something isn't made, nothing a little grinding, welding, and drilling can't solve.
All about that unibody life.
Xpress is offline
post #70 of 227 Old 12-25-2013, 10:38 PM Thread Starter
Jeep4MyKid
You guys are the best. It's really great to have everyone helping me through this, I'm so excited to learn more and figure everything out! I'd still be out there right now in the pitch dark working on it and trying to get it to drive again (lol) if it weren't for the fact that it wakes up the whole neighborhood when I start it @linusb, When I try to start it in park, the absolutely nothing happens except that the "brake" light on the dashboard comes on. There's no reaction at all from the rest of the jeep, it's as if I weren't even there.
post #71 of 227 Old 12-26-2013, 12:07 AM
mudsweatNgearz
1987 YJ Wrangler
Almost sounds like an interlock switch or something. I have a manual tranny but there should be a switch somewhere on the shift linkage that prevents starting in any position other than park and perhaps neutral. Sounds like the switch is messing up. Hopefully the auto tranny guys will chime in here.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #72 of 227 Old 12-26-2013, 12:30 AM
102joe
X2 check the shift linkage . It doesn't take much miss adjustment to get all crazy .The linkage should be comming down the fire wall under the brake master cylinder . Look for any signs it has moved or loose bolts . You should be able to figure out if its right or not .if you cant post up I ll get pics of mine tomarrow .
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline
post #73 of 227 Old 12-26-2013, 05:40 AM
Mark05059
take a hammer and pound on the brake drums while moving the ebrake cables around in a circle. they rust inside the casing. you need a new neutral safety switch if it starts in neutral... its ok to move it forward even if it means giving it a lot of gas...your brakes sound like they are still engaged by the ebrake cable not releasing fully
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #74 of 227 Old 12-26-2013, 10:55 AM Thread Starter
Jeep4MyKid
I don't exactly know where the cables are I went under there and it looked completely foreign, I'm the biggest noob there is to car stuff. Is there a way to just disconnect the Ebrake? I never actually use it, I was just testing it and look where it got me! Otherwise can anyone post pictures of the stuff I'm supposed to be hammering/shaking around?
post #75 of 227 Old 12-26-2013, 11:08 AM
pete1991YJ
This is not exact but its close. You are looking for the two black hose like things that plug in behind the wheels. This pic is from a cherokee, but the idea is similar
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
