just bought new lift - JeepForum.com
post #1 of 3 Old 03-26-2007, 09:38 PM Thread Starter
yjwrangler08
i am buying 33" 12.50 dunlop mudrovers. and need to know if 4" of back spacing would be enough to stop rubbing at full lock..i was also curious about how much slower it will go w/I4, 4:10 gears and 5 speed..and if puting a performance intake or exhaust would make a noticible change... Thanks Mike
yjwrangler08 is offline
post #2 of 3 Old 03-26-2007, 10:09 PM
sprngrider
I believe the lower the backspacing, the farther out the tire will be. Go with a little lower than stock and it shouldn't rub. Exhaust and intake mods will add noticable horsepower.
sprngrider is offline
post #3 of 3 Old 03-26-2007, 10:41 PM
OneCleanYj
4" BS will let you keep your stock turning radius
My 4 cyl isn't bad with the 33's and stock gears, but I do wish I had 4:88's. I can run 70-75 down the freeway with ease, good enough for me
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
The Lift You WISH You Bought Instead~ 4x4lover TJ Wrangler Technical Forum 34 01-10-2010 04:08 PM
03 TJ just bought - what lift would be best? scottrod13 TJ Wrangler Technical Forum 25 01-05-2009 02:12 PM
I just bought the lift mitchf350 Wrangler General Discussion 1 12-01-2008 02:52 PM
Just bought a lift BENGALSMUSIC TJ Wrangler Technical Forum 14 10-02-2007 02:43 AM
Bought used Jeep with OME lift, how do I tell how high the lift is? Baggerguy TJ Wrangler Technical Forum 6 01-01-2007 10:57 PM
