just bought a 93 yj Sahara, no O2 sensor,sputters - JeepForum.com
post #1 of 9 Old 05-04-2012, 04:43 PM Thread Starter
raceman77
This is my 4th jeep and not my first rodeo the jeep does have an aftermarket header on it. l cannot,for the life of me,find the O2 sensor. l searched the cat and unless l have to take off the underbody protective plate covering the cat,,,l can`t find a trace of it. The big problem is under hard acceleration the engine hesitates,sputters,goes flat and throws a check engine light. The light goes off once l`ve cycled the ignition on/off and the jeep runs fine at low throttle openings. l can rev it in neutral with no codes also. Any help with this would be greatly appreciated
raceman77 is offline
post #2 of 9 Old 05-04-2012, 06:07 PM
pete1991YJ
There should be a bung for the O2 sensor in the head pipe before the cat. Also there is definitely an error code stored in the computer. Might want to use the key trick to retrieve it. BTW welcome to JF, you've just found one of the best jeep sites anywhere!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #3 of 9 Old 05-04-2012, 06:18 PM Thread Starter
raceman77
thanks very much for the response.l`m just thinking that whoever ( PO ) installed the header they did away with the O2 sensor and the FI system has been running "open loop" since then... l really can`t find an O2 bung or sensor anywhere...
post #4 of 9 Old 05-04-2012, 06:56 PM
DRLongo
On a '91 there is only one o2 sensor and the boss for it should be about 6inches downstream of the header flange
DRLongo is offline
post #5 of 9 Old 05-04-2012, 07:27 PM
pete1991YJ
You're probably right - the computer will let you know for sure. I would try to find the plug on the wire harness and have a bung welded in. Most exhaust shops will do it pretty cheap, less than $40. Dunno why somebody would leave it out, when they run so much better with it.
If you can't find the plug, there are more than a few wiring experts around here. I have some of the diagrams from them. As far as which pin on the computer it supposed to plug into, etc.
post #6 of 9 Old 05-05-2012, 07:47 AM Thread Starter
raceman77
thanks guys, yeah any help is greatly appreciated.l`m going to be working on it today, heading out to the auto salvage to get some parts and all that. Does anyone know where the O2 pigtail should be?
post #7 of 9 Old 05-05-2012, 09:32 AM
OKwranglerYJ
Here's some pictures for you.
image-3769766799.jpg   image-2409259763.jpg   image-2321186635.jpg   image-989247920.jpg
OKwranglerYJ is offline
post #8 of 9 Old 05-05-2012, 11:02 AM Thread Starter
raceman77
awesome pics,thanks a lot. l just went to local auto salvage and got TPS , MAP and IAT sensors and a couple odds and ends but l should probably sort the O2 situation first before parts swapping...l`ll post my findings
post #9 of 9 Old 04-30-2013, 11:40 PM
scottieboy
I have this identical issue, by any chance did installing the o2 help? Was there maybe a bad cat because of the rich fuel ratio?
Or was it something else?
scottieboy is offline
Bought a 93 Sahara tonight. plac Wrangler General Discussion 127 03-16-2011 09:04 AM
just bought a 89 sahara mooseman0 YJ Wrangler Technical Forum 1 08-10-2008 09:57 PM
Bought an 02 Sahara Jasonoff TJ Wrangler Technical Forum 11 07-15-2004 09:40 AM
Just bought a 99 Sahara. Have some questions... blksahara TJ Wrangler Technical Forum 6 03-02-2003 06:08 AM
just bought an '03 Sahara! hangar18vfr TJ Wrangler Technical Forum 12 10-17-2002 03:09 PM
