Junkyard MPFI Problem - JeepForum.com
post #1 of 45 Old 07-10-2010, 04:14 PM Thread Starter
Douglas S.
Just finished my junkyard MPFI swap from a '92 cherokee into my '87 YJ. I have fuel and spark, but when I crank it it seems like it is trying to fire, but can't get going. Every few times the engine turns over it will seem like it's trying to start, but almost immediately dies. I tried reading the codes, but that doesn't seem to be working.
Any help is appreciated.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #2 of 45 Old 07-10-2010, 04:20 PM
idaholtby
Did you swap the flywheels over as well?
idaholtby is offline
post #3 of 45 Old 07-10-2010, 04:21 PM Thread Starter
Douglas S.
I used a Hesco CPS relocation kit on the front dampener.
post #4 of 45 Old 07-10-2010, 04:31 PM
idaholtby
Your '87 dash does not have a provision for the CEL lamp, so it would be difficult to check codes. You could hook up a noid light to power and -32 of the ecm connector and see if you can retreive any codes that may be useful.
post #5 of 45 Old 07-10-2010, 04:38 PM Thread Starter
Douglas S.
I tried putting a test light on the CEL output from the PCM and didn't get anything. I'm going to recheck that the distributor is properly indexed, but I'll try to retrieve the codes first.
post #6 of 45 Old 07-10-2010, 05:41 PM
ajs96
make sure you have the distributor indexed correctly, do a search on here...there are at least 4 threads with gross details to ensure it's correct, it's really easy to have it off by a tooth
ajs96 is offline
post #7 of 45 Old 07-10-2010, 08:59 PM Thread Starter
Douglas S.
Just went out and checked my codes.
12
34
33
41
54
55
The only problem here, that I can see, is 54. Not exactly sure what to do about it though.
post #8 of 45 Old 07-11-2010, 06:11 AM
idaholtby
54 is your distributer synch pick-up sensor. I assume you swapped over the distributers as well?
post #9 of 45 Old 07-11-2010, 10:12 AM Thread Starter
Douglas S.
I did, but I'm going to go to the junkyard and grab another dist to see if it solves the problem. I'm also going to install a fuel pressure gauge on the rail to ensure my fuel delivery system is up to par.
post #10 of 45 Old 07-11-2010, 11:48 AM
idaholtby
If the new distributer does not work for you, then ohm out the following wires.... For the '92 Cherokee harness from the distributer pick-up sensor connector... The Blk/Lt.Blu wire to ecm connector pin -4, The Org wire to ecm -7, the tan/yel wire to ecm -44. Good luck!
post #11 of 45 Old 07-11-2010, 12:14 PM Thread Starter
Douglas S.
Distributor didn't work, I'll give your suggestion a try.
What kind of resistance should I be expecting? 0 ohms for all?
post #12 of 45 Old 07-11-2010, 12:17 PM
idaholtby
Should be zero or reallllly close to it for each wire tested. Of course do this with the ignition off and battery disconnected.
post #13 of 45 Old 07-11-2010, 12:31 PM Thread Starter
Douglas S.
Yep, 0 on all three. This is starting to get annoying. Bad ECM? I know it usually isn't, but I'm beginning to wonder.
post #14 of 45 Old 07-11-2010, 12:37 PM
idaholtby
Also test each of these wires to a chassis ground as well. If one of these wires is shorted to ground anywhere, you will still read good continuity between both ends, but could also be shorted to ground. Beyond that, several other sensor tie into the same wiring and could be causing an issue. I would suggest in the very least for you to pick up a Chilton's that covers the '92 Cherokee to aid in your troubleshooting. It would be difficult to troubleshoot all the possibilities over the internet. This way you can continue troubleshooting on your own, and when questions arise, report back to the forum for help.
post #15 of 45 Old 07-11-2010, 01:28 PM Thread Starter
Douglas S.
Ok, here's where it gets weird.
I disconnected the battery to check for the resistance in those wires and following reconnection attempted to start it again, and there were some glimmers of hope (seemed like it was catching, but wasn't quite there) as well, code 54 was gone.
I made a small adjustment to the timing just by turning the distributor body. After cranking for a few seconds it caught, ran rough for a few seconds and then immediately shot to about a billion rpm's and I shut it down. I can keep trying to start it, but it still shoots to WOT.
mpfi or tbi garin3 YJ Wrangler Technical Forum 2 10-14-2007 09:32 PM
Bolt on MPFI losfelizwheelz YJ Wrangler Technical Forum 9 09-16-2007 12:49 AM
Converting a 2.5 from TBI to MPFI NoMotiv867 YJ Wrangler Technical Forum 1 06-19-2007 05:50 AM
what should i do about MPFI? ElvisV04290 YJ Wrangler Technical Forum 3 10-24-2006 04:13 AM
4.2 MPFI conversion help LAFEET YJ Wrangler Technical Forum 13 10-02-2003 08:49 PM
