Quantcast JunkYard Mods or Upgrades - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > JunkYard Mods or Upgrades
Old 03-30-2002, 05:41 AM   #1
JeepinNH
Are there any direct fit mods or upgrades to a 91YJ 4.0L 5SP. Trans, TC, Drive Shaft, Diff ???
I hate to spend alot of my hard earned money if I don't have to. thanks
91 Wranger, 3" body lift, 33" tires
everything else - stock
thinking about RC lift
Wife's has 91 Wrangler, Shackle Lift running BFG 31" "Yellow"
JeepinNH is offline   Reply With Quote
Old 03-30-2002, 04:35 PM   #2
evilpsych
direct fit.. hrmm... well.. if you want 4.10's i suppose you could just swap in axles from a 4cyl YJ out of a junkyard.. they come with 4.10's already and should be a direct bolt on.. however they may cost more than just paying for new rings.. and you'd have to get the alignment done also..
other than that.. everything else costs $$$$.. unless you find a junkyard that has a totaled jeep with all the parts there anyway
Awwwwwwwwwwww... So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline   Reply With Quote
Old 03-30-2002, 05:19 PM   #3
Mastaman65
I'm not tryin to walk all over your post, but i couldn't h elp but notice your jeep setup is almost the exact same as mine, 91 yj 4.0l 3" body lift and 33" tires, does your jeep perform well with the body lift? and how does it ride on/off road? thanks and sorry <img border="0" title="" alt="[Wink]" src="wink.gif" />
Mastaman65 is offline   Reply With Quote
Old 03-31-2002, 05:32 AM   #4
JeepinNH
Hey Mastaman65, no problem with the question. This is the setup that came with the Jeep when I bought it 2 years ago. Off road is very good, I was surprised. Lockers and a little more lift would help though, without it it's more of a challenge. On road 5th gear is useless, but I do not do alot of highway driving. My jeep does have other issues but not related to the lift. I also think it makes it easier to work on the extra clearance above the frame.
As far as my original post, my question is in response to another post I read. It said that a 90+ somthing Grand Cherekee came stock with headers that you could get cheap at a junkyard to upgade a wrangler. So my question is are there any non Wrangler model parts that are also a direct fit for my Wrangler. I met a guy in the woods once that told me he had Chevy S10 springs on his Jeep???? thanks
Glock Forum
