Junk Yard Feul Injection - JeepForum.com
post #1 of 2 Old 12-20-2001, 07:24 AM Thread Starter
battlestar
Can I put a 4.0 head and mpi on a 258 without buying the mopar mpi kit? I've read about putting the 4.0 head on the 258, so I know that is possible. The question is, while I'm at it, can I get the multi port feul injection at a junk yard and install that too. I thought that I read that the original equipment feul injection senses crank shaft position from the flywheel, and I believe the kit does it from the damper. Any body have any info on this? It would save me about $1500. My 258 only has 80k on it and I think it has quite a bit of life left in it, but it could use some extra hp and obviously the carb sucks big time.
My Ride: 1990 YJ, 4.2, 5 speed, msd ignition, TFI Cap, 4" skyjacker lift, 1/2" shackles, nutter bypass, bestop seats, herculined floor, Flowmaster, Oversized cat, Xterrains on Rock Crawlers
battlestar is offline
post #2 of 2 Old 12-21-2001, 10:02 PM
odie
try the weber carb, just put one on my 1990 jeep 6cyc big difference.
odie is offline
Project Junk Yard red87yj YJ Wrangler Technical Forum 30 10-26-2009 08:45 AM
What was that PDC from the Junk Yard? Reverb YJ Wrangler Technical Forum 2 10-21-2009 07:53 AM
4,2 went bad. need answer to swop to feul injection please. skip-yj YJ Wrangler Technical Forum 7 05-13-2009 06:59 AM
DIY Junk yard TBI Ratmeat YJ Wrangler Technical Forum 6 11-30-2008 02:53 AM
I just found out there is a junk yard that I have an in at NEWtoTHEjeepLIF TJ Wrangler Technical Forum 5 09-30-2005 04:39 PM
