Jumping out of 4 wheel - JeepForum.com
post #1 of 8 Old 02-05-2013, 04:24 PM Thread Starter
aeewsdt
I bought a 95 YJ Rio Grande the other day. When i test drove it, I engaged the 4 wheel and it worked fine. But when I got home, I had to reengage it, and it started popping out of 4-wheel drive. It did this in 4H and 4L. The front diff was low on oil, but everything looked to be ok there. I did notice that when I would engage the 4 wheel, the front drive shaft seemed to have play in it from the transfer case. I have a 231J x-fer case, and a 4cyl 5 speed. Is there some way to check and see if the transfer case is not fully engaging, or should I be looking somewhere else? You can hear a loud pop when it jumps out of 4 wheel.
aeewsdt is offline
post #2 of 8 Old 02-05-2013, 04:40 PM
Mark05059
when it pops out does the lever move or does it just make the pop? Makes a difference as to where to start looking...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 8 Old 02-05-2013, 06:01 PM Thread Starter
aeewsdt
No..the lever doesnt move at all. Just a pop and jerk.
aeewsdt is offline
post #4 of 8 Old 02-05-2013, 08:50 PM
jokerchief462
Try adjusting the linkage. Down on the side of the T-Case drivers side is where the shifter goes in but you will see a small nbolt 10MM head on the linkage. Put in 2H which is all the way forward and check position and then 4L which is all the way back. Check again and see if the linkage can be moved to get the shifter furter back in 4L and then try iit and check it out.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 8 Old 02-06-2013, 10:02 AM
Siva283
Check the CAD on the front axle too. It may be losing vacuum and disengauging the 2 peice shaft
Ask me how I know...
Siva283 is offline
post #6 of 8 Old 02-06-2013, 11:16 AM
squishy
I had/have a similar issue pops out when I put a hard load in it but the shifter doesn't move.
The first time I found that the PO had possibly ran the case out of fluid an overheated the chain which made it stretch. I replaced the chain problem solved -ish.
It started happening again ....when puttin the chain in I looked passed replacing the plastic pieces on the shift fork. Bad idea. I now have a 2wd jeep till payday and I can get a master rebuild kit.
(I have a 231)
squishy is offline
post #7 of 8 Old 02-09-2013, 04:16 PM Thread Starter
aeewsdt
ty for all the useful info.. I have adjusted the linkage a bit to see if that would help. Unfortunately, no...
I went ahead and purchased a new transfer case, which I am putting in tomorrow. I had ordered some nerf bars, and grill guard for it, and they just came in. So, I am gonna install all of it at once. I will let you all know how it works, and post pics of the finished product.
Thanks again for all the help.
aeewsdt is offline
post #8 of 8 Old 03-05-2013, 10:01 PM Thread Starter
aeewsdt
That x-fer case seemed to solve the problem. But I did find a vacuum leak in the system too.
aeewsdt is offline
