**Juice Box Ignition upgrade?** - JeepForum.com
post #1 of 4 Old 12-21-2001, 08:49 PM Thread Starter
odie
Own a 6 cyc 258 automatic 1990 jeep islander does anyone know much about these ignition upgrades are they worth it. Im looking for ways to improve cold start idle and acceleration. null
odie is offline
post #2 of 4 Old 12-21-2001, 09:39 PM
Bob K
Bob K's Avatar
I just installed mine this afternoon. It is a quality product. The components are well worth the cost. Easy to install. I haven't had much chance to test it out yet. Starting is improved, though wasn't a problem. Greatly improved idle, particularly when cold. I don't notice a difference in power or acceleration, though that may come with a little more spark advance. Overall it appears to be worth every penny. A stronger spark will ignite a lees perfect mixture. A less than perfect mixture is the nemesis of BBD carbed Wranglers.
I'll let you know more after the weekend when I have a chance to drive it more. I think you can't go wrong with this product.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 4 Old 12-22-2001, 11:52 AM
glm 87 wrangler
yes I too have also done this and it starts easier and runs better but my nutter bypass top it off a long with the weber.So if you try these mods it maybe the only ones you will have to do.The TFI that www.driveajeep.com offers is probaly the best way to go because some of these parts are hard to find.Plus the coil comes with its on mounting bracket and can be bolted right on the passanger side finder.So no worring about making a setup for it. plus it comes with all the wires and stuff you need.Put it on set the timming and go! thats it!Later
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #4 of 4 Old 12-22-2001, 12:29 PM
Darko
go to www.Jeepz.com they have a carter BBD carb fix that would fix your cold idle and starting. The problem on the Carters is the Venturi clogs, which gives you a rich mixture, ther is a write up there, there is also another write up on a TFI upgrade with parts from a Ford 300CID I6. It has all the parts numbers you would need, so you could go get them at the local parts store. Good luck
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
MSD ignition upgrade for the 4.0HO ? Mystion TJ Wrangler Technical Forum 12 01-18-2010 01:33 PM
Juice box iginition upgrade ? Tuffy YJ Wrangler Technical Forum 1 07-20-2008 05:25 AM
ignition upgrade blkhwk8 TJ Wrangler Technical Forum 2 03-14-2008 10:01 PM
ignition upgrade hepcat75 YJ Wrangler Technical Forum 1 02-28-2008 07:41 PM
the juice box upgrade Meister_jeep YJ Wrangler Technical Forum 7 09-08-2002 06:06 PM
