jk wheel hubs on a yj - JeepForum.com
post #1 of 10 Old 08-18-2011, 09:58 PM Thread Starter
CMFast
I've got some JK wheels I want to put on my YJ, but I don't want to use wheel spacer/adapters. My front wheel bearings have 165,000 miles on them so I'm wanting to know if I can just put JK front wheel hubs on my YJ. The reason is the YJ bolt pattern is 5x4.5 and the JK is 5x5. The spidertraxx are going to run me $200 for front and rear and I'd rather spend the money on new hub bearings and alloy axles in the rear. I've looked up the part numbers on NAPA and they're different but I think it only has to do with the JK having the ABS sensor in the wheel hub and the YJ does not. Anyone have any idea's on this?
CMFast is offline
post #2 of 10 Old 08-18-2011, 10:04 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Your only option is to get the adapters ............ or buy some wheels with the correct Bolt Pattern
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 10 Old 08-18-2011, 10:43 PM
timatoe
timatoe's Avatar
I don't think so. I guess you could buy one and try it.
timatoe is offline
post #4 of 10 Old 08-18-2011, 10:49 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Is the spline count the same or even the same diameter? I thought I read somewhere that the jk uses a special size internal spline for the bearings and there aren't too many replacements to bypass the abs sensor on them. I'd like to see how this turns out...
Luck Favours The Prepared
Anticanman is offline
post #5 of 10 Old 08-19-2011, 07:21 AM Thread Starter
CMFast
ok, then what about redrilling the old hubs from 5x4.5 to 5x5? I need to get to NAPA and compared the overall diameter between the two and see if there is enough metal left on the hub. If the diameter is the same from YJ to JK then redrilling to 5x5 should work, right?
CMFast is offline
post #6 of 10 Old 08-19-2011, 07:36 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I didn't say your original idea wouldn't work, I just said that there may be hiccups along the way. I definitely would not drill a new bolt pattern on to existing hubs, but that's just me. Try your jk hub theory out, it might work.
post #7 of 10 Old 08-19-2011, 08:09 AM
Spuznick242
I wouldnt bother. It's not worth it unless you really LOVE those JK rims. If anything your best and easiest route would be to get the adapter. Use breaks as a time to upgrade, dont use maintence as an excuse to upgrade, replace the wheel bearings and then get the adapter.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #8 of 10 Old 08-19-2011, 09:51 AM
timatoe
timatoe's Avatar
Regardless of the front, how are you planning to address the rear?
timatoe is offline
post #9 of 10 Old 08-19-2011, 10:23 AM
Spuznick242
Ment to add that in as well but completely forgot after I caught s*** for being on the forum before I "ate breakfast and got a shower".
post #10 of 10 Old 08-19-2011, 06:35 PM Thread Starter
CMFast
the rear is going to be an 8 3/4 Chrysler with Moser axles drilled to whatever I specify. I wanted 16" wheels and I got a good deal on them. Then I saw the price of the adapters and my good deal went out the window.
CMFast is offline
Wheel inserts to mate with hubs?? Grinner JK Wrangler Technical Forum 9 03-14-2011 08:23 PM
Wheel spacers with Warn hubs Tinga TJ Wrangler Technical Forum 1 01-18-2011 06:57 PM
Who makes NTP and Duralast wheel hubs? dbdragracing YJ Wrangler Technical Forum 4 09-13-2010 04:26 PM
Loose wheel hubs???? Journeytojeep YJ Wrangler Technical Forum 8 03-15-2006 09:41 AM
greasing wheel hubs rjl2001 YJ Wrangler Technical Forum 3 12-23-2002 03:06 PM
