JK D44 swap thread for my YJ - slowly - JeepForum.com
post #1 of 457 Old 01-10-2011, 08:30 PM Thread Starter
ldso
Edit: This has started to turn into a resto-mod thread for my YJ. It does include swapping a rear JK Dana 44 in.
Here is the parts list and cost.
Well it's taking a while, but I'm slowly putting together a JK Dana 44 swap into the rear of my YJ. It's going slow enough that I am making this thread between paydays...
I started two years ago with a stock 1995 YJ Rio Grande.
Then after about six months and my wedding and honeymoon, I ordered the Rough Country 4" kit and installed it with my buddies, and got the transfer case drop welded up so I can drop the transfer case skid when I want. I put new exhaust on.
Then I got a deal on some 34" Swampers and went on my first wheeling trip. I'm the dude standing there watching my buddy's H3 fail to pull out my rig.
I spent most of the day stuck and it was really cold out. Some dudes on a quad brought us a come-along and we learned about having recovery equipment and CBs. I put in an Aussie Locker in the Dana 35.
Did more wheeling and my buddy's TJ ate a shaft.
I helped him put chromoly shafts in his Dana 35. Started planning on doing an axle swap.
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #2 of 457 Old 01-10-2011, 08:33 PM
PlatinumNiner
So where are the pix of your swap and why not just go 8.8 for much less $ and a stronger axle?
PlatinumNiner is offline
post #3 of 457 Old 01-10-2011, 08:41 PM
MLJeeper
MLJeeper's Avatar
How much did you give for the JK 44?
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #4 of 457 Old 01-10-2011, 08:41 PM Thread Starter
ldso
Got an arc welder and a Smittybilt rear bumper. Did some more wheeling and some road trips, and found that 34's with 4.10 gears and the 2.5L sucks on the highway. Got some 31's and Cragar Soft 8's.
All along the way I was fixing things, replacing torx bolts with hex bolts, new starter, etcetera, as I could afford it. My windshield frame started falling apart on the highway hehehe, got a new frame/seals/windshield/hinges/mirror movers. Got a CB and a winch. My wife bought me some new Bestop seats. The Rough Country kit settled a good bit, so I did a 2" body lift with hockey pucks. Then I decided that my rig was pretty capable, and the next priority was an axle swap.
I started saving some money and thinking about ordering an axle from ECGS, when a JK Dana 44 from an '08 Unlimited showed up on Craigslist. Showed it to my buddy, he called right then and offered the guy $200. He took it! So I went to the ATM and got $200, and my buddy picked it up for me. Guess he really wanted me to do an axle swap hehehe
ldso is offline
post #5 of 457 Old 01-10-2011, 08:44 PM
MLJeeper
MLJeeper's Avatar
$200s not bad at all
MLJeeper is offline
post #6 of 457 Old 01-10-2011, 08:44 PM Thread Starter
ldso
I was planning on the 8.8 but fate decided on the D44 There are no swap pix because I am still putting parts together.
ldso is offline
post #7 of 457 Old 01-10-2011, 08:45 PM
MLJeeper
MLJeeper's Avatar
I realize your cutting it off, at least i hope so, but its always baffled me why they mounted the shocks so low on a JK (offroad vehicle).
MLJeeper is offline
post #8 of 457 Old 01-10-2011, 08:57 PM Thread Starter
ldso
So that was like September. Then my wife's 40th was in October, and then in November I got some spring perches and shock mounts from M.O.R.E. Then in December all my money went to Christmas. The axle didn't come with any brakes, the guy that had the JK swapped to a D60 and reused the brakes from his 44.
So I got a quote from Don't Fear The Jeeper (11RUBICON here on JF) for brakes for my axle around Christmas time, and ordered them on my next payday, and today they showed up.
I got two backing plates, the left and right calipers, and brake pads. The axle did come with rotors.
Next I still need to get 2 studs pressed back into one of the axle shafts (got borrowed by the 4x4 shop that did the swap for the guy), u-bolts and spring plates. And I need to make the JK D44 pinion bolt to my driveshaft.
Then I still need to make hard lines and figure out how I'm going to make the YJ brake line hook up. Then once I grind all of the brackets off the axle it will be ready to line everything up and weld the new perches and shock mounts on. At that point I will have a rear axle with 5on5 hubs and 3.73 gears, and a front axle with 5on4.5 and 4.10s Got a ways to go.
ldso is offline
post #9 of 457 Old 01-10-2011, 08:57 PM
autoboy454
probably to run a longer shock, so that it would be "more capable" off road and wouldn't suffer from fade after a long run on jouncy, bouncy dirt roads. Jeep sacrificed ground clearance, and all the pro's these days just cut big shock hoops thru the tubs lol.
Love to wheel? Live in/around Massachusetts? Check us out!
autoboy454 is offline
post #10 of 457 Old 01-10-2011, 09:03 PM
MLJeeper
MLJeeper's Avatar
Yeah i understand the physics but it still seems lower than necessary.
Anyway why you have to press studs on? BFH man!
MLJeeper is offline
post #11 of 457 Old 01-10-2011, 09:10 PM Thread Starter
ldso
Also last Thursday I found a deal on a daily driver/tow rig, so the YJ is going in the garage to put up on jackstands for the surgery.
So now I have another project, I need to fab up a front bumper so I can flat tow the YJ behind the Avalanche. My wife and dog love the new truck
After daily driving a 4-cylinder YJ for two years, Dios Mio, V8 power, quiet and a smooth ride rocks
ldso is offline
post #12 of 457 Old 01-10-2011, 09:11 PM
autoboy454
You can also use a lug nut with an appropriate length spacer to suck the stud back in it's place. Or just put the rim on the shaft, and tighten the lug with the ole impact
post #13 of 457 Old 01-10-2011, 09:12 PM Thread Starter
ldso
THanks man, I couldn't pass it up! It was saying "take me home"! Even after having to buy brakes, and having to change carriers and gears, and figure out the wheel adapter issue, it will still be a good deal
ldso is offline
post #14 of 457 Old 01-10-2011, 09:15 PM Thread Starter
ldso
Makes sense to me, good theory!
I'm not sure yet how high I can mount the shock mounts. It seems like the shocks are mostly compressed at rest in the normal position on the Dana 35. I will play with the fitment and try to compromise between not hitting the shocks on rocks and making sure there is enough compression in the shocks.
ldso is offline
post #15 of 457 Old 01-10-2011, 09:16 PM
jeep0312
Subscribed
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
ok, another axle swap thread.. House TJ Wrangler Technical Forum 7 08-31-2011 07:27 AM
8.8 Swap Into TJ Build Thread GreenJip TJ Wrangler Technical Forum 154 04-14-2011 04:30 PM
89 4.2 to 96 XJ 4.0 Swap Thread w/ wiring green89yj YJ Wrangler Technical Forum 41 02-15-2011 06:20 PM
My "slowly upgrading" build thread... geo1400 YJ Wrangler Technical Forum 10 01-14-2010 02:38 AM
2.5 to 4.0 swap thread... redjeep669 YJ Wrangler Technical Forum 4 11-29-2006 09:02 AM
