#jeeproblems just once i'd like a prob thats easy not like this trans - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > #jeeproblems just once i'd like a prob thats easy not like this trans
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 10-12-2012, 03:57 PM   #31
pete1991YJ
pete1991YJ's Avatar
Originally Posted by riverhippy View Post
pete, do i need to reclock if the tc comes from a wrangler?
Nope.
Only if its from a cherokee. If the TC came from a Wrangler that had the AX-15 then you don't need to do anything at all, not even a conversion kit.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline   Reply With Quote Quick reply to this message
Unread 10-12-2012, 09:00 PM   #32
czjeeper
On the re-clocking subject.
I have an extra AX15 from an XJ.
What's the best/easiest way to drill? Anybody have a template?
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club
Click here for 2.5L AX5 to AX15 swap
czjeeper is offline   Reply With Quote Quick reply to this message
Unread 10-13-2012, 12:04 AM   #33
riverhippy
Originally Posted by pete1991YJ View Post
Nope.
thanks pur!!! how much u want? and peeee-TAY! thanks as always bro....is there any way my ******* could tell the diff if a tc is from a jeep and the other from a faked jeep (cherokee)?
riverhippy is offline   Reply With Quote Quick reply to this message
Unread 10-13-2012, 09:35 AM   #34
riverhippy
I can see why everyone loves the AX15. i layed the 3 and 4 gear sleeve from the ax5 next to the 15.
Unread 10-13-2012, 10:00 AM   #35
pete1991YJ
pete1991YJ's Avatar
Far as I know, there isn't any way to tell the difference between an wrangler tC and an cherokee TC just from looking... there isn't any template that I know of for the bolt holes. Most guys just put it in and if it dfoesn't fit right they give it a twist until it does, and then use the TC itself for a pattern to re-drill the flange on the trans adapter housing.
Unread 10-13-2012, 11:08 AM   #36
riverhippy
one question: im trying to save myself the step of getting a diff drive shaft. will a tc from a wrangler do this?
Unread 10-13-2012, 02:44 PM   #37
pete1991YJ
pete1991YJ's Avatar
The drive shaft is the same regardless of the TC you get as far as I know. If you get an 8.8 rear or a SYE (or both) *then* you have to worry about driveshafts.
Unread 10-14-2012, 10:43 PM   #38
riverhippy
ax153a from indonesia
1
Unread 10-14-2012, 10:47 PM   #39
riverhippy
ax15 trans: 300
transfer case--23spline (blowme) 150
parts to make a 4 ton bearing press (SUPRISE!) $150 and counting) ---this is the expense i LOVE....it is so glossed over its retarded.
add at least 100 for the tools i bought to make the press and try to do this.....
Unread 10-14-2012, 11:01 PM   #40
czjeeper
I think you may have mis-read/researched something.
My AX15 went it in a few hours.
4 ton press? Too many beers?
US Army combat vet
Unread 10-14-2012, 11:09 PM   #41
riverhippy
smallest (cheapest) bottle jack at harbor freight...i wish i drank....might start. thanks for your input...)...i just found a bottle of teh-kee-la? is that how its pronounced?
Unread 10-14-2012, 11:22 PM   #42
czjeeper
Okay, reading back through your post...you can't swap shafts between the AX15 and AX5 that I know of.
Measure the input shaft snout on your AX15. There are a couple different sizes.
Verify your pilot bushing/bearing is correct for that size.
What bearings are you trying to remove?
US Army combat vet
Unread 10-14-2012, 11:37 PM   #43
riverhippy
thanks for yr intrst cper
if you scroll down you'll see a pic of a case bare ax15 and a gear sleave from an ax5. although i did both of these teardowns...i had no desire to.
i have a 91 with a 2.5 and thought a beefier ass15 would be good.
to answer yr question directly, none. i dont wish to change any bearings. what do i have to do to get a transmission back in my jeep so i can get back to work?
i was told that swapping the input shafts from my old ax5 to the new ass15 would allow me to be driving it. thats not gonna happen.
Unread 10-15-2012, 04:59 AM   #44
YJames90
What about a NP231C ? Its got the spline count that you want. Mine is a NP231C/J Trans side Chevy, Rear side Jeep
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4...begun-1237704/
YJames90 is offline   Reply With Quote Quick reply to this message
Unread 10-15-2012, 08:32 AM   #45
czjeeper
Okay, I may have missed it, but do you have a Dakota 2.5 bellhousing or adapter plate from AA/Novak?
Without one, the AX15 isn't going to work.
US Army combat vet
ax15 , hot girl with tat , jeep girls like it dirty , sucks , thiscantendwell
