Jeep YJ Won't Start!! Need to fix this ASAP! - Page 3 - JeepForum.com
post #31 of 51 Old 03-24-2013, 02:19 PM
Que89YJ
Ok. So you are losing power from the ignition switch to the relay. At the ignition switch connector there should be a yellow wire. Turn the ignition to start and check power to that wire.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #32 of 51 Old 03-24-2013, 07:40 PM Thread Starter
SKYOFSCORPIONS
I tested the power to the yellow wire, look at the pic below for reference. I'm not 100% sure if it was the connector to the ignition switch though. I'm also not fully sure if I was testing it right since the negative (black) cable on the volt meter wasn't being used. I put the positive to the metal end of the yellow wire, then turned the key/ignition; All I got was a 00.00 reading.
SKYOFSCORPIONS is offline
post #33 of 51 Old 03-24-2013, 08:16 PM
Siva283
You need to ground the black wire from the meter. You can ground it to the body. There should be some ground wires attaxhed by the ebrake peddle. Just geound it there.
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #34 of 51 Old 03-24-2013, 08:34 PM Thread Starter
SKYOFSCORPIONS
@Siva283, I had the black wire touching bare metal on the Jeep body, I failed to mention I did that since I didn't know what else to do.
post #35 of 51 Old 03-24-2013, 08:37 PM
Siva283
That should have done it. I will refer you back to Que. I still have a lot to learn about electrical ill stick the to easy stuff for now.
Siva283 is offline
post #36 of 51 Old 03-24-2013, 08:58 PM Thread Starter
SKYOFSCORPIONS
Yep, there was no power coming to the end on the yellow wire when I turned the key like when starting the Jeep.
post #37 of 51 Old 03-24-2013, 09:13 PM
Que89YJ
So you measured the yellow wire at the ignition switch when you were turning it to the start position?
Fault codes:
No Start:
Que89YJ is offline
post #38 of 51 Old 03-24-2013, 09:41 PM Thread Starter
SKYOFSCORPIONS
Well the yellow wire in the picture above. That plug of wires is located under the dash and attached to the steering column. I unplugged that thing and each wire has a metal part; so the yellow wire's metal end, that's what I measured when I was turning the ignition to the start position. It didn't get any voltage. So my guess is it might be the ignition cylinder or the wire in the steering column.
post #39 of 51 Old 03-25-2013, 07:58 AM
Que89YJ
It sounds like the switch out the rod that goes to the switch. Just to make sure find a hot wire in the ignition column area and jumper power to the yellow wire and see if it cranks. If it does then post back and I will take you to the next step.
Fault codes:
No Start:
Que89YJ is offline
post #40 of 51 Old 03-25-2013, 08:06 AM
Siva283
So you unplugged the connector when you did the test?
Que doesnt he need to back probe that wire for this test?
Siva283 is offline
post #41 of 51 Old 03-25-2013, 08:52 AM
Que89YJ
Yes. The connector has the battery power on it! Did not catch that. Thanks. Use a pin and put it into the connector. It is called back pinning.
Fault codes:
No Start:
Que89YJ is offline
post #42 of 51 Old 03-27-2013, 07:47 PM Thread Starter
SKYOFSCORPIONS
So I plugged the connector back in. I then tested with the meter which wire was getting voltage. Both the orange and the green wire had power.
They read 12.78
So then I took a paper clip, unwound it and slid it into the back of the connector to touch the orange wire end. I used the meter to test the paper clip's voltage. That read 12.78 as well. I then bent it over and put it into the yellow wire.
This is the reading I got on the paper clip then.
I moved the paper clip around a bunch to see if I could get a different reading. I then tried the ignition turned in different postions. Nothing was making it read different than 8.68. I then unplugged the connector and tried to do the same thing again but on the female part of the connector. I got the same exact results.
So I was able to get those readings, but nothing happened, nothing tried to turn on. What do you think??
post #43 of 51 Old 03-27-2013, 08:50 PM Thread Starter
SKYOFSCORPIONS
After some research, I'm not 100% the yellow wire I've been testing is the ignition/starter wire. I looked at this and there is another area on the upper side of the steering column. I'll play with this tomorrow.
http://www.jeepforum.com/forum/f12/b...witch-1226376/
post #44 of 51 Old 03-27-2013, 08:53 PM
stmanser
is it possible that while you were cutting of the tails of the zip tie, you may have accidentally cut through a wire that was close to the tail you were cutting off?
something to look for at least.
stmanser is offline
post #45 of 51 Old 03-27-2013, 09:14 PM Thread Starter
SKYOFSCORPIONS
No, there were only 2 zip ties. Nothing has been cut, I've checked.
battery , ignition , starter
