Jeep YJ Won't Start!! Need to fix this ASAP! - Page 2 - JeepForum.com
post #16 of 51 Old 03-22-2013, 04:12 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The last thing you messed with was wiring under the dash. That is where I would concentrate my efforts. Wiring along the steering column are very important they go to everything to do with starting this rig. Make sure the ground by the emergency brake is tight also.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #17 of 51 Old 03-22-2013, 05:44 PM
Que89YJ
Did you jumper pin 30 to 87 and see if the starter cranked?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #18 of 51 Old 03-22-2013, 06:10 PM Thread Starter
SKYOFSCORPIONS
I don't have a spare wire. But a brand new relay didn't work.
I the next test I did was where plugged the relay in halfway. I slipped the volt meter under the relay and touch the front pin (it was 30 or 87), I read 12.24 volts. Then I touched the other pin (30 or 87, not the side pins) while someone turned the ignition; the meter read 00.00 volts. So my conclusion is that the problem is sending the signal to the relay to power the starter. I bet it has to be either a wire issue or the ignition cylinder.
SKYOFSCORPIONS is offline
post #19 of 51 Old 03-22-2013, 06:15 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
When you turn the ignition to the ON (not START) position does your CEL light up for several seconds?
post #20 of 51 Old 03-22-2013, 07:21 PM Thread Starter
SKYOFSCORPIONS
The CEL comes on for a little past 2 seconds. The e-brake light is on as well since I have that engaged. Also the fuel pump starts up and the 9 volt works when the key is turned. Also the heat works. Just if I turn the key more to start the car, nothing happens.
post #21 of 51 Old 03-22-2013, 08:13 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
The CEL coming on right away for a few seconds when you turn the key to the ON position usually indicates that the ECM is OK.
I keep hopping on the fact that the jeep ran until you started tie wrapping wiring under the dash. It is where I would concentrate my initial efforts to see if I had done anything physically. Looking elsewhere until I was completely satisfied that nothing was fubar'ed makes no sense to me unless you shorted a wire out.
I would pull every fuse in the fuse panel and in the PCM and check everyone of them for continuity with a multi-meter just to eliminate them as a possible culprit also.
post #22 of 51 Old 03-23-2013, 06:06 AM
Que89YJ
Jemper 30 to 87 and see if the starter turns over, I can tell you where to go next I just need to know the power side is good and the control side is bad.
Que89YJ is offline
post #23 of 51 Old 03-23-2013, 10:35 AM Thread Starter
SKYOFSCORPIONS
@laybackman, the first thing I checked was the wiring. I've checked it probably 3 times, spent 40 minutes making sure everything looks good.
@Que89YJ, I'll give this a shot. Let me look for something to jump them with.
post #24 of 51 Old 03-23-2013, 02:07 PM Thread Starter
SKYOFSCORPIONS
I was able to jump 87 and 30 pins with a paper clip.
post #25 of 51 Old 03-23-2013, 09:26 PM
Que89YJ
did the starter turn over?
Fault codes:
No Start:
Que89YJ is offline
post #26 of 51 Old 03-23-2013, 11:26 PM Thread Starter
SKYOFSCORPIONS
Yes! Jumping 30 to 87 started the motor just fine.
post #27 of 51 Old 03-24-2013, 07:03 AM
Que89YJ
OK good. NO on the same relay I want you to use a meter and on the other 2 pins 86 and 87 I want you to take the black meter lead ground and attach it to the negative battery terminal and using the positive lead check power on 86 and 87 while you have someone turning the ignition to the start position. You are looking for 12 vdc. If you don't have a meter a test light will work.
Que89YJ is offline
post #28 of 51 Old 03-24-2013, 07:58 AM
Blackfish
Did the starter turn over when you jumped bewtween the pins
My boss made the comment that "I bet you missed me over the holiday break",my response was "yes your right I did, but my aim is getting better"
Blackfish is offline
post #29 of 51 Old 03-24-2013, 10:28 AM
Siva283
The two post above you would point to yes. I don't envy the op looks like he is gonna be tracing wires betwwen the relay and steering column. Atleast you got Que in your corner. He is really good at making things that seem comp licated rather simple to do.
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #30 of 51 Old 03-24-2013, 01:10 PM Thread Starter
SKYOFSCORPIONS
@ Que89YJ, the other pins on the relay get no voltage when turning the key. The meter read 00.00 when testing them.
battery , ignition , starter
