Jeep YJ round headlight conversion - JeepForum.com
 14Likes
post #1 of 60 Old 07-21-2017, 09:03 AM Thread Starter
Perdido1
Good morning! New to the forum and to Jeeps after a very long absence and I have many questions. This is a father-son project and my son prefers the round headlight look of the CJ and TJ. Our grill us in good condition, but both fenders are needing replacement and the hood ain't too great either! What's the simplest way to go about a project like this? I removed the grill and fenders this morning and that was about a 2 hour job since no fasteners were rusted tight (lucky me). I'm a very visual person and pictures would be great!
Thanks, Rut
Perdido1 is online now
post #2 of 60 Old 07-21-2017, 09:13 AM
project_mercy
Like you said, you toss the hood, fenders and grill, and you make the radiator, shroud and grill fit in the proper spot and then rewire all the things.
See: http://www.fourwheeler.com/how-to/bo...-yj-into-a-cj/
Or: https://www.google.com/search?q=YJ+t...hrome&ie=UTF-8
Edit: Upon reflection, I guess you don't actually have to do a full CJ swap if you just dislike square headlights and don't mind welding. Technically you could modify the crap out of the YJ grill to give it round headlights. You'd need to cut the old headlight buckets out, and fill in the metal and adjust the grill slots nearest the headlight and then put round headlight buckets in. You'd lose some cooling.
With your help I will resist the urge to buy a chrome grill guard for yet another day.
project_mercy is offline
post #3 of 60 Old 07-21-2017, 11:56 AM
mark1305
mark1305's Avatar
Lots of good threads with good pics scattered throughout here. I don't have any links to them, but I lifted some pictures from two different builds. One that just cut out and swapped the CJ headlight area into the area from which the YJ lights were similarly cut out. Not too much filler sheet metal had to be welded in.
In the other, the whole CJ grill skin was removed from its frame then cut and shortened below the turn signals to fit onto a YJ grill frame. The backwards bend of the YJ grill was bent into the new CJ skin. And some sheet metal filler pieces were welded in around the gaps at the top corners.
I'm eventually going to do a conversion on mine. I have an extra YJ grill and a CJ grill. One of the above methods will be the way I go. Someday....
mark1305 is offline
post #4 of 60 Old 07-21-2017, 03:26 PM
timatoe
timatoe's Avatar
@DirtKar just did this, maybe he can shed a bit of light on it for you.
timatoe is offline
post #5 of 60 Old 07-21-2017, 04:00 PM
NHfireLJ
NHfireLJ's Avatar
SOME ONE SHOULD BE BANNED.... Or go buy a JK.... Kidding, good luck
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #6 of 60 Old 07-21-2017, 08:09 PM
mark1305
mark1305's Avatar
I stand by my excuse - my rebuilt title says 84 CJ (and there are 84 CJ parts on it) but the frame/tub/transmission/TC all say 89 YJ. Of course axles and other stuff span even more years as I have found out doing brakes and stuff.
So I'll go for it. And still have my YJ grill should I have to swap back. I know this is a serious subject... and I take the tongue in cheek slings and arrows in good fun. Like someone posted recently, it's still a YJ.
Now back to that plastic grill abomination...
NHfireLJ likes this.
mark1305 is offline
post #7 of 60 Old 07-21-2017, 09:55 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Here's all of my cheat sheets. I used a CJ grille, fenders, hood and radiator. I relocated the power steering res over to the passenger side and made a bolt in bracket for the grille support out of 1/4"x2" steel. The radiator hoses had to be changed, a couple of universal bendy jobbers did the trick. Aside from those items it's pretty straight forward. PM me if you have any questions.
CJ front swap
http://www.jeepforum.com/forum/f12/c...s-pics-431224/
http://www.jeepforum.com/forum/f12/m...thread-708391/
https://www.google.com/search?hl=en&...ts=&gws_rd=ssl
http://www.jeepforum.com/forum/f12/c...to-yj-1161039/
http://www.pirate4x4.com/forum/jeep-...ight-suck.html
95-99 Ford contour fan wiring
http://www.jeepforum.com/forum/f8/my...-swap-1164486/
Controller wiring
http://www.gearheaddiva.com/3031/how...an-controller/
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #8 of 60 Old 07-22-2017, 07:18 AM Thread Starter
Perdido1
DirtKar,
Thanks for all the great information and I'll sit down with my son to see if he's up to it since this will be his Jeep. I restore British sports cars from the 50s, 60s, and 70s in my retirement and the construction of the CJ and YJ are not very different from those. I'm building this Jeep outside since I lost my shop last November along with all my tools, 2 restored cars and a ton of parts to a fire. That said I've found that a lot of the fasteners are metric and standard (at least not imperial, BSP, Whitworth, etc.) and I'm curious if that's the case for most Jeeps of this era. I've ordered a few catalogs and they are helpful, but I don't have a shop manual yet...what's a good one?
Thanks again, Rut
DirtKar likes this.
post #9 of 60 Old 07-22-2017, 07:21 AM
StanF
Dirtkar, did you have to go to the Contour fan for clearance?
StanF is online now
post #10 of 60 Old 07-22-2017, 07:35 AM
fishadventure
Originally Posted by Perdido1
DirtKar, Thanks for all the great information and I'll sit down with my son to see if he's up to it since this will be his Jeep. I restore British sports cars from the 50s, 60s, and 70s in my retirement and the construction of the CJ and YJ are not very different from those. I'm building this Jeep outside since I lost my shop last November along with all my tools, 2 restored cars and a ton of parts to a fire. That said I've found that a lot of the fasteners are metric and standard (at least not imperial, BSP, Whitworth, etc.) and I'm curious if that's the case for most Jeeps of this era. I've ordered a few catalogs and they are helpful, but I don't have a shop manual yet...what's a good one? Thanks again, Rut
Yes, they did an excellent job blending inch and metric fasteners. So both wrench/socket variants are needed.
Good choice on the CJ front direction. The TJ nose/front has round headlights, too, sure, but ugly looking grill, awful marker lights, and unimaginative, ungrateful hood.
You don't really need the catalogs. IMHO. There's very little yuh need in them. But a lot of things to separate you from your money.
The Haynes or Chilton manual is OK for reference and basics. A factory service manual will be a good accompaniment for those, and far more good information.
If there's a rig I plan on keeping for a while, I tend to buy several used manuals for it from Amazon: a Haynes, a Chilton or Bentley, and a factory service manual if I can find it or download one electronically.
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
post #11 of 60 Old 07-22-2017, 08:45 AM
mark1305
mark1305's Avatar
What fish said. Metric and imperial throughout. And the Haynes manual has some good info and some half truths and/or omissions - usually regarding the task you are ready to undertake. I have a FSM for my daughter's 2000 XJ, but for the most part my YJ is simple and basic enough that my experience over the past 50 years of wrenching gets me through. Oh, wait. And all the myriad questions I get answered on here.
mark1305 is offline
post #12 of 60 Old 07-22-2017, 09:34 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Originally Posted by Perdido1 View Post
DirtKar,
Thanks again, Rut
The '93 FSM seems to be elusive. At least a free one that is. There may be someone that has one here. I found a guy on a different forum, that has a '94 FSM that you can download. Not too much was changed between '93 and '94. PM me for the link.
If you want to pay for one, do a Google search, you'll find them anywhere from $10 to $60.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #13 of 60 Old 07-22-2017, 11:00 AM
fishadventure
Originally Posted by Mr.B
The '93 FSM seems to be elusive. At least a free one that is. There may be someone that has one here. I found a guy on a different forum, that has a '94 FSM that you can download. Not too much was changed between '93 and '94. PM me for the link. If you want to pay for one, do a Google search, you'll find them anywhere from $10 to $60.
The electrical is actually the only difference that anyone will ever notice
post #14 of 60 Old 07-22-2017, 12:32 PM
DirtKar
DirtKar's Avatar
No, I had about 4" clearance with the CJ radiator. When I attempted this a couple of years ago using the YJ radiator I didn't see near that much. I have a 1" body lift which I believe would throw the shroud off. I don't have a stock shroud to test that theory. I like the efans and the contour fan fits the CJ radiator like it was made for it.
YJOTM JULY 2014
DirtKar is offline
post #15 of 60 Old 07-22-2017, 12:49 PM
mike134
For anything before 1990, you can pretty much always use the 1990 factory service manual which is available on the internet. I think it includes both peurgeot and AX-15 transmissions even though the 1990 did not have a Peurgeot.
For 1991-1995, the 1995 factory service manual which is available from redneckgarage's youtube page can be used almost exclusively.
mike134 is offline
Perdido1
