Jeep YJ Rear Axle Upgrade Options - Page 2 - JeepForum.com
post #16 of 27 Old 02-27-2013, 04:23 PM
linusb
For what you describe, a new axle probably not even needed. As fragile as D35's are made out to be, a few guys in my club wheel them and I've not seen one of them break. If it breaks, then upgrade or just fix.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #17 of 27 Old 02-27-2013, 06:59 PM
calvynandhobbs
calvynandhobbs's Avatar
When I bought my YJ my plan was to put a 8.8 in it with stock 4.10 gears and find a 4.10 geared D30 for the front, but The Super 35 and matching D30 popped up and I jumped on it. Up to 35s this combo should last me a long time.
94 YJ - work in progress
calvynandhobbs is offline
post #18 of 27 Old 05-06-2013, 10:56 AM Thread Starter
Bravo1782
I'm running 33x12.5x15s...I've seen plenty of super 35 kits, and they're pricey, but will it fix the problems common to the c-clip D35? Which is the cheaper\better option? Upgrade D35 with d35 super kit, or get an 8.8\d44 and drop in a locker?
Bravo1782 is offline
post #19 of 27 Old 05-06-2013, 11:03 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
8.8 with a locker. Hands down.
You've got to remember that even though a super 35 is significantly stronger than its stock counterpart, you've now hit a ceiling with where you can go with it. If you break something on a super 35, you can't throw money at it to make it stronger you can only replace it. So if a super 35 is as strong as a stock 8.8 and you're looking at upgrades down the line the choice is clear. Plus the money will be saved over the super kit by buying a ford axle and fitting and upgrading the differential yourself. There is a reason you see so many threads about swapping a Dana 35 to a ford 8.8. Look around the site and you'll find hundreds and not just in the Yj section but also in the TJ section and even outside the wrangler spectrum like xj and ZJ swaps.
You could do the entire axle swap sans locker for the cost of converting to disk brakes on your Dana 35.
Luck Favours The Prepared
Anticanman is offline
post #20 of 27 Old 05-06-2013, 11:05 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
And one more thing: if you think that a c clip eliminator and disk brakes will get you off the trail with any less damage than c clips and drum brakes think again. I know it looks nice on paper but it isn't true.
post #21 of 27 Old 05-06-2013, 03:06 PM
dukeryder
Why do you want to upgrade in the first place? Just because you've read on the internet that the D35 is weak? or have guys you wheeled with broken theirs? I live where there is some of the most hard core off roading that I've ever seen in my life, and I still see guys running Dana 35s with 33" tires (almost every lifted TJ; except Rubis, I see around here is on 33s and has a stock rear axle). From what I've seen the guys breaking stuff are doing some hard core trails, like stuff a stock Jeep couldn't dream of going or hammer on the throttle, (although some people claim the D35 can break from mall crawling).
All that being said, I went the 8.8 route. My YJ came with a 3.07 which after going to just 31s was geared way too tall for this altitude (even the 4.0 looses power at 8,000') and the steep hills around here. The 8.8 isn't an EASY swap, you need to be able to weld; I was lucky enough to find a local fab shop that swapped an 8.8 w/ 4.10 gears and a LSD; and regeared the Dana 30 to match for $1,030. Even if I could set up gears on my own and weld, I couldn't have done it any cheaper and it was only $250 more than if I had just regeared the D35, so it was really a no brainer despite the 8.8 probably being a little overkill for my 2.5" lift and 31s.
dukeryder is offline
post #22 of 27 Old 05-06-2013, 03:38 PM
Ripper3494
I feel like that's not even a serious question. There is every reason to upgrade from the 35
Sent from AutoGuide.com App
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #23 of 27 Old 05-06-2013, 03:57 PM
jbolty
jbolty's Avatar
The problem with the D35 c-clip eliminator is that it does nothing to fix the small diameter flexy axle tube. The flex in the tubes will cause lead to breakage of the spider gears unless you add a truss which is just throwing more money at a weak axle.
If someone wants to wheel on a D35 and they are easy on the gas I see no reason not to let it go until it breaks. But they had better be carrying spare shafts, tools and the knowlege of how to fix it on the trail. I have wasted far too many hours waiting around for Mr It-never-breaks.
jbolty is offline
post #24 of 27 Old 05-06-2013, 05:19 PM
bowtech
I swapped out to an 8.8, upgraded front and rear to 4.88 gears and installed ARB locker. No regrets what so ever. I still run the D30 up front with Chrome molly shafts and eliminated the disconnect on the D30.
bowtech is offline
post #25 of 27 Old 05-06-2013, 05:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sounds like a good jeep. You should fill in the profile so I can item et stalk your jeep.
post #26 of 27 Old 05-06-2013, 08:27 PM Thread Starter
Bravo1782
I think you nailed it. The biggest reason I want to upgrade is peace of mind. I want to know that I've invested as much as I reasonably can to get as tough a Jeep as humanly possible. I know that the D35 MIGHT hold up, but I feel like if I upgrade, I'll probably NEVER (fingers crossed) have to worry about this stuff in the future. Kinda the whole "buy the best and you only cry once" strategy.
post #27 of 27 Old 05-13-2013, 08:07 PM
linusb
That's why I did, plus the satisfaction of taking on a major project. I made mistakes along the way but I feel like I learned a lot and really boosted my confidence toward tackling other things.
linusb is offline
