Jeep YJ Rear Axle Upgrade Options - JeepForum.com
post #1 of 27 Old 02-26-2013, 01:28 PM Thread Starter
Bravo1782
Hey guys, just finished paying off my wheel\tire upgrade on my axles. In this thread, I want to ask you guys about where to start on the rear axle. The D35 on the YJ has a history of bad problems, so I realize a direct swap makes the most sense. That said, swap with what? A D44? Ford 8.8? If so, from what vehicle. I plan to put a locker of some sort, but what makes the most sense? A LSD, soft locker, or hard locker? Re gearing is inevitable, so what gear ratio?
I'm not a serious mudder or rock crawler; my YJ is primarily an expedition vehicle, that is, I take it off-roading mostly to get to places to camp, and then spend the weekend wheeling around getting to places. I don't plan to climb up mountains with it. What do you guys think? What the best and most cost effective route?
Bravo1782 is offline
post #2 of 27 Old 02-26-2013, 01:30 PM
giggityjeeper
read this has been covered, beat to death, and covered again, 8.8 and 44 are ver close in strength..... 8.8 from a 95 up explorer gives u disc brakes and is with an inch i beleive of bein the same width.... its the most common really...
start reading
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #3 of 27 Old 02-26-2013, 01:52 PM
NHfireLJ
NHfireLJ's Avatar
SOOO MANY OPTIONS AND OPINIONS..,
Do some research.... search different lockers. search 8.8
You need to research first and then come back with specific questions
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #4 of 27 Old 02-26-2013, 02:08 PM
zeus87gn
1987 YJ Wrangler
I used a Chrysler 8.25 from a Cherokee - It was available when I went looking and all ready ready to bolt in (spring perches already moved)
Some say its not any better than the D35, but XJ drivers don't have any problems...even up to 35s
As far as the internals -> Detroit TruTrak
JMHO
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #5 of 27 Old 02-26-2013, 02:24 PM
imstillatwork
Imagine a horse that died of unknown causes. Cause is irrelevant anyways. Point is, the horse died. Day after day, for the better part of 10 years, passersby proceed to beat the crap out of said horse. With each beating clearly more meaningless than the previous. Our subject- the horse- is now a bloody pool of putrefied flesh pounded into a pulp.
All kidding aside,
Start here. This is probably the most complete set of pages regarding YJ axle swaps
http://bit.ly/Yypdx1
imstillatwork is offline
post #6 of 27 Old 02-26-2013, 04:28 PM
calvynandhobbs
calvynandhobbs's Avatar
Like said above, this has been beat to death, but just as an FYI, neither the 8.8 or D44 are direct bolt in. There is fabrication to be done with anything that didn't already come under a YJ. What you can look for that would be a direct bolt in is a "Super 35" already built. I picked up a "S35" with 4.88 gears, Detroit locker and truss with a matching D30 front axle with 4.88 gears and Lockrite for $500. I don't know if the 35 will last, but it was worth the gamble. He was going up to tons so I had to give it a shot.
94 YJ - work in progress
calvynandhobbs is online now
post #7 of 27 Old 02-26-2013, 04:31 PM
Ripper3494
8.8 is your easiest most covered swap. strong as hell thick tubes, big gear and heavy shafts. just cut all original mounts off and weld on new spring perches. then get a new u joint that fits for both the axle and your jeep and your done...
if your know what your doing (ie. research) and you have the parts you need (2 spring perches and a new u joint) the swap can easily be done in under 2 hours
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #8 of 27 Old 02-26-2013, 07:01 PM
linusb
Not sure what tire size you have, but if running 32-35, Find a 4.10 geared LSD 8.8 out of ford explorer Eddie Bauer ( or sport model also has I think). Pretty easy swap. Cost you to tune of 300-400 bucks if u can find someone to do free welding/labor to help you.
Find a complete Dana 30 with same gearing, put an auto locker in it. Total Cost maybe 400 bucks.
Sell your old axles...recoup maybe 150.
With this setup you'll have a very capable rig on and off road - on the cheap!
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #9 of 27 Old 02-26-2013, 08:48 PM Thread Starter
Bravo1782
Thanks, LINUSB....and everyone else. I guess I should have been a little more specific with my original post...I was hoping to get some insight from some YJ guys that have done these swaps, wheeled them, and came back with an overall assessment on how it went.
I think the biggest thing for me is going to be what I can find and what parts are available...I feel like (from what I've seen) there's FAR more options for a D44 than a 8.8 as far as gears, diff covers, lockers, etc...but maybe I'm just looking in the wrong places...I'll just keep my eyes peeled on what turns up at scrap yards.
Here's another question for you guys: Regearing: should I DIY or drop the note to get someone else to do it, if it comes down to that. It seems involved, but then again, so did installing an SYE, until I actually did it and looked back thinking "well hell that wasn't bad." What do you guys think?
post #10 of 27 Old 02-26-2013, 09:07 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There is almost as much aftermarket support for the 8.8 as the 44 because of two reasons:
1) the 8.8 never came in a solid steering axle
2) the vehicle which the 8.8 came was rubbish from the factory.
Luck Favours The Prepared
Anticanman is offline
post #11 of 27 Old 02-26-2013, 09:20 PM
rambo3489
Look into a 9" too. It's the big brother of the 8.8. Much stronger design. Wonderfully tuff design. But has drum brakes. Convertable to discs for some money. But if you are not looking for a heavy duty axle if go 8.8. Easier and better option of the two.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #12 of 27 Old 02-27-2013, 06:06 AM
soonermatt
You didn't give budget requirements but did talk about buying something used. You could look at some Rockwell axles out of an old military surplus Kaiser truck. You might be able to find some Eatons out of an old city dump truck. I don't think you'll have to worry about strength with either of these options. They should hold up on the trail going to the camp site like you mentioned.
soonermatt is offline
post #13 of 27 Old 02-27-2013, 06:25 AM
Ripper3494
Probably sent from under my broken heep
build thread:
RC vs BDS
post #14 of 27 Old 02-27-2013, 08:58 AM
StanF
Originally Posted by Bravo1782 View Post
snip
What size tires are you running?
Axle replacement might be your best option...
For your use case, you might want to consider upgrades to your D30/D35 instead. Read this thread for info on what another guy did:
http://www.jeepforum.com/forum/f9/ex...hafts-1234745/
StanF is offline
post #15 of 27 Old 02-27-2013, 09:29 AM
jeepster93
jeepster93's Avatar
This.
The only direct drop in for a YJ is the one it came with. There is NO junk yard axle that will bolt under your Jeep without modding that you don't already have.
jeepster93 is offline
