Jeep YJ Pinion yoke play.... - JeepForum.com
post #1 of 3 Old 04-28-2013, 04:52 PM Thread Starter
navis
Hi Everyone,
I developed a bad drive-line vibration over the last couple of days. Assuming it was a U-joint issue I pulled the rear drive shaft. The u-joint at the pinion was totally shot with all the bearings dissolved in one of the caps. Upon further inspection I noticed that the pinion yoke has a bit of play on the pinion shaft. It seems to be moving around on the flange very loosely. Here's a link to a video of how it's moving around:
I am planning an axle swap soon but the Jeep needs to carry on as my daily driver for about another month or two. If I replace the u-joints and carry on is an explosion inanimate?
Thanks for any help!
navis is offline
post #2 of 3 Old 04-29-2013, 07:36 AM
bogleparsons
Try to tighten the pinion yoke nut and see if that helps.
Mine was loose once and just needed tightening. You may need a new nut also.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #3 of 3 Old 04-29-2013, 09:34 AM
jokerchief462
Romove the yoke and replace it. New nut and rubber gasket torque to spec and see what happens.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
