jeep yj oil selection. - JeepForum.com
post #1 of 10 Old 10-28-2012, 09:45 PM Thread Starter
jeepyjLeD
Hey gus. I have a jeep yj with a ford 8.8 rear and a Dana 30 front. Bother are regeared to 4.88. I'm
Wondering what type of oil I should use in each one if I'm doing 75 on road 25% offroad
jeepyjLeD is offline
post #2 of 10 Old 10-28-2012, 09:48 PM
dillonjm
2013 WK
Standard gear oil.
Add LS additive as required (if your 8.8 has limited slip).
Its a waste of money to run high dollar oils in a differential. Especially if your going to change it frequently due to wheeling in wet conditions. My 2 cents.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is online now
post #3 of 10 Old 10-28-2012, 09:53 PM Thread Starter
jeepyjLeD
So like 75 w - 140?
post #4 of 10 Old 10-28-2012, 10:06 PM
CaptLeeB
I run 80w-90. There will be different answers and different reasons. Just make sure you have gear oil in it. Like Dillonjm said if you have LS get an additive.
CaptLeeB is offline
post #5 of 10 Old 10-28-2012, 10:08 PM Thread Starter
jeepyjLeD
No limited slip. Just open open for now
post #6 of 10 Old 10-29-2012, 12:17 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Then any 90wt oil will work. That 25% offroad will catch up with you and you'll change it often enough searching for water. I suggest a lubelocker front and rear. I bought my front but stuck with rtv for about six months and after cleaning up the mess out back I got another lubelocker for the 8.8. Best oil change investment you'll ever buy.
Luck Favours The Prepared
Anticanman is offline
post #7 of 10 Old 10-29-2012, 08:16 PM Thread Starter
jeepyjLeD
I have a lube looking in the rear already. Definetly Ghana get one for the front
post #8 of 10 Old 10-29-2012, 11:03 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Good on you, mate!!
post #9 of 10 Old 10-30-2012, 11:14 PM Thread Starter
jeepyjLeD
Thanks for the help guys
post #10 of 10 Old 11-05-2012, 06:30 PM Thread Starter
jeepyjLeD
Ended up using Lucas 85w-140
