Jeep YJ Oil Leak - JeepForum.com
post #1 of 9 Old 12-16-2015, 10:25 PM Thread Starter
dylynclark
Jeep YJ Oil Leak
Is there anyway to actually STOP it from leaking? I've had the rear main seal replaced as well as all the other seals and it STILL leaks.
Any suggestions?
dylynclark is offline
post #2 of 9 Old 12-16-2015, 11:09 PM
jred
Autozone has a sale on oil right now...
jred is offline
post #3 of 9 Old 12-16-2015, 11:43 PM
baritone_mike
The easiest way to stop it from leaking is to put less in it.
Where is it leaking from? If you can't tell get some simple green and go to town on the engine, once it is factory spotless take it for a drive and look for oil. Mine mainly leaks into the air box, the little bit that leaks out of the oil cap dries on the valve cover before it can run down and drip, so at least it is self contained and does not leave spots.
Are you 100% it is leaking from the motor? The manual transmission takes engine oil, the transfer case takes automatic transmission fluid, and both axles take gear oil.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #4 of 9 Old 12-16-2015, 11:52 PM
TSEJEEPERS
Valve cover. Last I checked you have to buy the valve cover to get the right seal.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #5 of 9 Old 12-17-2015, 09:35 AM
Fozzybear42
+1 on valve cover, that's where mine leaks from. Hoping to take care of that soon.
Fozzybear42 is offline
post #6 of 9 Old 12-17-2015, 09:54 AM
mike134
the Fel-Pro reusable rubber valve cover gasket is a worthy investment, as long as you combine that with maintenance on the PCV and/or orifice and vacuum lines.
mike134 is offline
post #7 of 9 Old 12-17-2015, 03:48 PM
bruinjeeper
bruinjeeper's Avatar
+1 on mike134's advice.
If there is too much pressure inside that cover... it will blow out somewhere. Because our engines are not exactly straight and tilted to the rear (and its impossible to see back there) it will force itself out back there and you will never be the wiser without a 90* dentist mirror
(could be worse, these pressures have been known to blow that pressure and oil right onto your air filter). Since you gotta take the cover off - clean it up real nice... remove baffles and clean up nice. Make sure those gaskets are in tact and just get new valves and grommets. Not expensive and should be done if never done before.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is offline
post #8 of 9 Old 12-17-2015, 04:21 PM
Drednot
Most likely, you have a PCV(CCV) issue. My 91 doesn't drip a drop since I replaced the valve cover with the good fel-pro rubber gasket, oil filler cap, and unplugged the CCV orifice.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #9 of 9 Old 12-17-2015, 05:04 PM
gotswap
Ditto on the above, fel-pro gasket, new oil fill cap and PCV system go through fixed my leaks.
gotswap is online now
