Jeep YJ hard top restoration (write-up with lots of pics!) - Page 4 - JeepForum.com
post #46 of 55 Old 03-20-2013, 07:27 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Originally Posted by southbound View Post
Yeah, it's been awhile, so I don't have the link on hand. That being said, I know they make two different types. One with the defroster tabs, and one without.
Well that's good to know. I think the hardtop has a rear defroster(has the lines on the back window). It's not original to my Jeep so I was never sure which to get. Thanks for the help.
Michaelgoesrawr is offline
post #47 of 55 Old 03-22-2013, 08:25 AM Thread Starter
southbound
Check your dash for the switch. It will be next to your fog light and rear wiper switches in that little panel. If you have the dash switch you're good to go.
5.7L Hemi TJ Build: http://forum.aev-conversions.com/showthread.php?t=7434
southbound is offline
post #48 of 55 Old 03-22-2013, 09:01 AM
Michaelgoesrawr
Not if my Jeep had a soft top from factory. That location is blank on mine.
post #49 of 55 Old 03-22-2013, 03:38 PM Thread Starter
southbound
Check out frost fighter. It's a DIY defroster kit. You can buy the switch and the wiring from them and wire it to your hardtop.
post #50 of 55 Old 03-22-2013, 06:28 PM
Michaelgoesrawr
Good to know. I was just going to wire it up myself with a timer relay. Winter is almost done here though so ill do it next winter
post #51 of 55 Old 08-09-2013, 02:11 AM
extremebiker
1987 YJ Wrangler
How much sanding did you do to prep the hardtop before painting it and lining it. This build thread is incredible though. Thank you for your hard work.
extremebiker is offline
post #52 of 55 Old 08-09-2013, 11:57 AM Thread Starter
southbound
No a whole lot. I like the textured surface on the outside. Just enough to scuff it so the primer would have something to sink into and bond with. Same thing for the inside.
I've since sold this Jeep, but the hardtop was one of the big selling points. I further sealed the lip on the windshield with this dark brown putty from Lowes that's used to seal around windows. It did a great job and all but silenced the wind on the road. The liner also did a great job at reinforcing the top itself and insulating outside sound. After it was lined the hardtop would no reverberate on the highway at high speeds.
Glad I'm able to help. This was a really fun project that I had to put some effort into as most of these parts are no longer in production. I can't recommend going with as much stainless steel hardware as possible too. All of the screws and bolts on mine were rotten when I got the hardtop. Jeep obviously didn't do a good job sourcing corrosion resistant hardware for their hardtops as every one I've seen has some kind if rust going on.
This is what it looked like when I sold it. It held up great after 3 years of use. I'm sure it's holding up fine as I really took my time making sure everything was done right with the best materials.
post #53 of 55 Old 08-30-2013, 07:03 AM
winning
http://i641.photobucket.com/albums/u...rpaneldone.jpg
Did you put a gasket or weatherstripping between the fiberglass piece at the bottom of the liftgate and the glass? What about the piece on the inside of the glass at the bottom that bolts to the outside piece? I'm restoring mine and your write up has been very helpful. Mine had a foam gasket that was soaking wet and the square brackets that are threaded that fit inside the fiberglass piece were almost completely disintegrated. I've replaced almost every bracket and bolt with stainless or aluminum.
winning is offline
post #54 of 55 Old 08-31-2013, 07:10 PM Thread Starter
southbound
Yeah, those gaskets for the back are impossible to find. They would probably cost an arm and a leg if you found them online. That being said, I went to Pep Boys and got the 1" wide grey foam weatherstripping. Then I cut it to cover the back side of the fiberglass panels on each side.
I also used this putty-like weather stripping on the base of the posts to fill in around the holes in the rear glass. I never had any issues with leaks or moisture. It worked great and sealed tight when everything was tightened down.
Here is a photo of the weatherstripping I'm talking about:
post #55 of 55 Old 01-27-2017, 09:05 PM
zrickety
Just wanted to say thanks for an informative thread and pics that still work!
1988 Jeep Wrangler Laredo
zrickety is offline
94 YJ Restoration ...PICS !!! theboxman71 YJ Wrangler Technical Forum 1063 08-15-2015 04:39 AM
CJ Grill on a YJ (write up, lots of pics) Varnish YJ Wrangler Technical Forum 57 07-14-2013 01:57 PM
My little hard top lift write-up (pics) OregonVette JK Wrangler Technical Forum 25 07-18-2011 01:06 PM
First pics of my '95 restoration.... tomesd YJ Wrangler Technical Forum 122 03-25-2011 04:10 AM
Some pics of my 91 YJ restoration YJBlues YJ Wrangler Technical Forum 5 12-23-2005 08:20 PM
