jeep yj four wheel drive solution - JeepForum.com
post #1 of 9 Old 01-14-2014, 10:03 PM Thread Starter
gwest50
For the record jeep yjs are amazing of road vehicles but it kinda stinks when you 4x4 doesn't work, the vacuum line is prone to failure so I went ahead and bought front end perm. Lockers and they work great just for the record
gwest50 is offline
post #2 of 9 Old 01-14-2014, 10:10 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Moving this clip over fixes it for free
Luck Favours The Prepared
Anticanman is offline
post #3 of 9 Old 01-14-2014, 10:31 PM Thread Starter
gwest50
Where is that clip located?
gwest50 is offline
post #4 of 9 Old 01-14-2014, 10:38 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Inside the central axle disconnect located on the axle housing itself.
post #5 of 9 Old 01-14-2014, 10:50 PM Thread Starter
gwest50
Thank you
gwest50 is offline
post #6 of 9 Old 01-15-2014, 05:01 PM
JFranko
What was posted above, going to a cable system, or putting in one piece shafts will all fix this.
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline
post #7 of 9 Old 01-15-2014, 07:58 PM Thread Starter
gwest50
Any advise on ground clearance?
gwest50 is offline
post #8 of 9 Old 01-15-2014, 10:55 PM
JFranko
suspension lift and tires, or a 1 inch body lift and a high clearance skid plate will both give you more clearance. Doing a u-bolt flip kit will also give you a little more clearance under the springs, and make them a little better at sliding over stuff instead of getting hung up.
JFranko is offline
post #9 of 9 Old 01-16-2014, 10:44 AM
Siva283
Its only free if your front drive shaft is balanced
Ask me how I know...
Siva283 is offline
