jeep yj d35 yoke size? - JeepForum.com
post #1 of 5 Old 09-01-2011, 04:02 PM Thread Starter
jeepyj13
well found out my rear DS ujoints are failing due to having 5" lift and whatnot. went to parts store to price ujoints today but they gave me 2 different size ujoints according to the rearend yoke. so what size is the yoke?
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #2 of 5 Old 09-01-2011, 04:10 PM
scubamc
They should be 1310. If the joints are failing it is probably because your pinion angle is wrong.
scubamc is offline
post #3 of 5 Old 09-01-2011, 04:30 PM
TrentYJ
Yup, 5" of lift and a slip yoke normally don't get along too well. I'd recommend an SYE in the very near future or you'll be going through driveshaft parts like candy. Not to mention you'll probably lose a few teeth in the process
TrentYJ is offline
post #4 of 5 Old 09-01-2011, 05:15 PM Thread Starter
jeepyj13
Thanks for the info. Yeah i knw the lift is a 4" RC lift with their 1" boom shackles for the roughly 5" lift. Ima start saving for SYE kit soon. Was going to get 1 over the summer but my jeep funds ran alittle short when school began.
jeepyj13 is offline
post #5 of 5 Old 09-01-2011, 05:28 PM
SpikesHD
1987 YJ Wrangler
Please don't buy Precision brand joints (Yellow box, blue writing). Those things are worn out from the factory!
I realize they are lifetime warranty but heck, we sell an $11 American made joint that will last like an OEM.
Just wiggle the cap against the trunnion and you'll see.
Si vis pacem, para bellum.
SpikesHD is offline
hack and tap yoke??? th350 yoke or front t-case output yoke on rear?? 02wrangler_guy TJ Wrangler Technical Forum 5 02-15-2016 03:09 PM
What size nut on pinion yoke? bruker TJ Wrangler Technical Forum 9 03-02-2015 05:33 PM
SM465 Yoke Nut Size cubewhiz YJ Wrangler Technical Forum 0 08-16-2010 06:27 PM
dana 35 yoke size? canadiantj1999 TJ Wrangler Technical Forum 5 02-25-2010 07:16 AM
nut size on rear yoke antec YJ Wrangler Technical Forum 5 10-23-2009 03:44 PM
