Jeep YJ A/C blowing warm air - JeepForum.com
post #1 of 8 Old 08-10-2009, 08:07 PM Thread Starter
TyWebb04
I turned on the A/C today (rainy and muggy) and the air luke warm. I don't use th AC much, but i did have it on only a week or so ago and it was ice cold. All of a sudden it's not cold at all. The blower and everything seems to be functioning correctly. I did notice the fan making a weird noise when i engaged the knob that controls the A/C temperature.
Could it just need to be recharged? If so, where can i get R12? I'm pretty sure that is what it uses since it's a 1990.....
TyWebb04 is offline
post #2 of 8 Old 08-10-2009, 08:17 PM
stratons_yj
Somebody correct if I'm wrong but you can only get R12 if you are licensed in A/C.
But you could buy a kit to convert it to R134a...They are pretty cheap, it just threads on to the R12 low side port
stratons_yj is offline
post #3 of 8 Old 08-10-2009, 09:07 PM
dodger889
Turn the temp to the right is full on. With the fan running. Is the compressor kicking in?
You can get what is called Freeze 12 for an r12 system.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 8 Old 08-11-2009, 07:47 AM Thread Starter
TyWebb04
It sounds like the compressor is on, but hard to tell. If i start with the temp knob all the way to the left when i turn it just a little to the right i can hear something other than the fan turn on, I'm assuming that is the A/C compressor. However, i did notice that it was making a loud noise and seemed rough when i turned it on yesterday... Could i have a bad A/C compressor? Typically if you A/C runs out of refridgerant does it go out slowly or all of a sudden?
TyWebb04 is offline
post #5 of 8 Old 08-11-2009, 07:55 AM
Louie4
"You pass butter"
Louie4's Avatar
Open the hood to your jeep while its running with the A/C on and see if the compressor engages and turns. If it does, look in the sight glass on top of the drier (pass. side below head light). If you see bubbles you're low on freon. If the compressor doesn't kick on its either locked up or low on freon.
R12 is hard to come by these days, even harder when you aren't licensed to buy it. Last time I bought it, it was about $40 for a 12 oz. can. I'm going to swap over to R134a soon. If you do decide to do this, buy a new drier, and replace as many O-rings as you can. I'm also going to buy a new expansion valve because I think mine was freezing up before it went out.
Yes, you can use Freeze 12 but I think that stuff is a little dangerous. I have some cans at the house but I haven't used it. My dad actually bought some.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #6 of 8 Old 08-11-2009, 07:58 AM
pasinbuy
A freind of mine is a ac tech. He just put 134 in on top of the r12. My ac worked fine.
pasinbuy is offline
post #7 of 8 Old 06-22-2010, 02:11 PM
SloppyJoseph
Its $20 to take the test and get EPA Certified.....
SloppyJoseph is offline
post #8 of 8 Old 06-22-2010, 05:26 PM
dodger889
You are not suppose to mix the two but Hey if it works great. Just do not expect it to last.
I'm stumped, heater only blowing warm TXjeepTJ TJ Wrangler Technical Forum 16 12-20-2010 02:46 PM
Heater blowing warm air not HOT air all3forus TJ Wrangler Technical Forum 12 12-11-2008 08:18 AM
Out of Ideas and my MIND!!! (Heat only blowing moderately warm) jhaycock13 TJ Wrangler Technical Forum 36 11-19-2008 07:23 PM
Need to Warm-up the Jeep First, Why? dfowler TJ Wrangler Technical Forum 3 05-25-2007 03:27 PM
A/C blowing warm air eep3 TJ Wrangler Technical Forum 2 03-30-2006 06:14 PM
