Jeep YJ Bad idle need suggestions - JeepForum.com
post #1 of 3 Old 05-03-2012, 06:44 PM Thread Starter
jerseyjeepkid
I have a 1991/1992. It a Frankenstien jeep. anyway a few days ago it decided it did not want to run right. it idled real rough almost sounding like a built V8 in stead of 2.5L 4 cly and also drove much in the same matter. i just did new plugs cap/rotor and wires. still runs rougher then all hell. When I unplugged the throttle position sensor it smoothly idled up then when right back to the same routine. when plugged back in, there is no change. So i am wondering if the Throttle sensor can cause this and if not than what? also my Fuel pump is now audible which it never before this happened. PLEASE HELP! thanks!
jerseyjeepkid is offline
post #2 of 3 Old 05-04-2012, 01:26 PM
tomemt
when was the fuel filter changed
tomemt is offline
post #3 of 3 Old 05-04-2012, 01:35 PM
pete1991YJ
Get the error codes from the computer first. Its easy and free, using the ignition key. Here's a video that shows how.
BTW welcome to JF, you've just found one of the best jeep sites anywhere!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
2.5l , idle issue , idle jump , jeep yj , rough idle
Random sputtering and idle drops.. Any suggestions Whsperz TJ Wrangler Technical Forum 7 04-27-2012 11:29 AM
Running rough and low idle when hot, awful mpg, hot cat etc. etc. Suggestions? Dmcastino TJ Wrangler Technical Forum 1 09-14-2010 08:17 PM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 05:46 PM
Wierd Idle....any suggestions? None TJ Wrangler Technical Forum 40 01-23-2007 03:05 PM
TJ rough idle and tune up suggestions RckRdyXJ TJ Wrangler Technical Forum 3 03-22-2006 04:28 PM
